Sponsored by: Real Truck
Smell fuel
Old Feb 12, 2014 | 08:22 PM
Blackout's Avatar
Blackout
Smell fuel
Hey guys,
I'm new to the 6.0 side of the fence so I'd sure appreciate any help I could get..... I smell diesel whenever the hood is up but can't see anything leaking.... any idea where I should look?
cheers,
Dave
Old Feb 12, 2014 | 09:12 PM
Benchwrench's Avatar
Benchwrench
burnt or unburnt? Could be a modified Crankcase breather, an obvious fuel leak or an exhaust leak. Not much info to go on.
Old Feb 12, 2014 | 11:47 PM
Blackout's Avatar
Blackout
Hey Benchwrench,
It's unburnt and faint.
Old Feb 13, 2014 | 12:14 PM
Benchwrench
you'll most likely need to crawl around under the truck. Look around both primary and secondary fuel filter areas. Also look at the filler neck of the tank and the top of the tank as well for wetness. Check in front and behind both heads
Old Feb 13, 2014 | 01:46 PM
Blackout's Avatar
Blackout
Will do. I don't think it's tank related since I only smell it when I'm walking in front of the truck and when the hood is up.... I'll post my findings.
Thanks again,
Dave
Old Feb 13, 2014 | 07:55 PM
98SurplusExpy's Avatar
98SurplusExpy
Check your pressure regulator (on top-side fuel filter housing). They are notorious for leaking ...
Old Feb 14, 2014 | 10:18 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yup. This thing:
baja370
6.4L Power Stroke Diesel
Nov 24, 2015 04:36 PM
Wicked Endings
20
Jan 20, 2011 02:59 PM
deemac
Aug 17, 2007 12:19 PM
oldcoupe42
Jan 30, 2006 11:47 AM
