high boy power steering conversion
Old Feb 12, 2014 | 02:19 PM
bigcrunch's Avatar
bigcrunch
So my 73 HB has the factory power ram assist, I'd like to convert it to a integral PS box what box is popular to use for this?
Old Feb 12, 2014 | 04:42 PM
Roger Carter's Avatar
Roger Carter
Swap a power steering set up from a '78-'79 F-250 4x4. Not exactly a nut and bolt swap, but one way to go.
A search through this site should spell out the specifics.
Back in the before times we used a power steering gear from a mid 60's T-bird or Lincoln for the conversions. The install looked to be identical to the factory '78-'79 system.
Good luck.
Roger Carter
Old Feb 12, 2014 | 05:23 PM
64rarebird's Avatar
64rarebird
I am waiting on my 78/79 4x4 p/s box to arrive , little hard to find but i got lucky and bought one from a fellow fte member while researching the power steering swap for my 77 highboy i did run across this posting on another site lots of good pics not sure if its the best way or not but looks like a clean install
http://www.truckowners.com/content/6...-Ford-Highboys
Old Feb 13, 2014 | 11:03 AM
bpete's Avatar
bpete
I have used a 73-79 2wd box. Cheap and very plentiful. A little frame and inner fender trimming & boxing. Used the pitman arm off of the 2wd turned it 90 degrees I think. carefully used a die grinder to enlarge tapered hole tapered reamer too expensive for me. P/S lines for 2wd were used. Used a new chevy drag link 73-87 I think to finish up. That was in 1999. Hope this helps..
OrangeBeast
17
May 28, 2012 06:06 PM
cfish36
20
Apr 13, 2007 08:29 PM
engineguy33
Nov 16, 2006 10:04 PM
7FORD2
Jan 2, 2006 11:51 PM
truckfarmer
Offroad & 4x4
Jan 8, 2004 11:52 AM
