hot lightswitch
Old Feb 12, 2014 | 01:27 PM
dutchford150's Avatar
dutchford150
hot lightswitch
I have a 95 f350 and the lightswitch gets hot as hell after 25 minutes when the lights are on
is there a way so it does not overheat?
regards George
Old Feb 12, 2014 | 01:37 PM
stainlessstroker95's Avatar
stainlessstroker95
Lmc truck has a harness to help prevent that. But you may want to go ahead and replace the switch too.
Old Feb 12, 2014 | 02:45 PM
DarkStarMedia's Avatar
DarkStarMedia
Yea, Change the switch before it melts. That usually means that the switch is dieing.
Richard
Old Feb 13, 2014 | 07:13 AM
echo95's Avatar
echo95
The LMC truck headlight wiring harness is an easy fix as it removes the current that runs through the switch through a remote relay instead. There are others that fabbed up a harness as well with heavier gauge wiring.
Old Feb 13, 2014 | 11:14 AM
stainlessstroker95
Truck Parts and Truck Accessories
Old Feb 13, 2014 | 11:30 AM
thomabb's Avatar
thomabb
The heat is a symptom of the contacts inside the switch are in bad shape. Whatever you do, you should also replace the switch.
Old Feb 13, 2014 | 12:32 PM
dutchford150
thanks guys for the quick response
I will go for the new harness and switch
grts George
Old Feb 13, 2014 | 04:27 PM
paddler's Avatar
paddler
Another vote for LMC harness
No cutting of existing wiring. Plugs into existing headlight bulb plug on one side, then connect to battery positive and ground. Other existing headlight plug gets disconnected and not used. Harness has "new" plugs, controlled by the relay.
Quick, easy, and rather foolproof.
You can assemble a functional equivalent for less, but without the "bulb plug" in the harness, you'll have to cut into the light wiring on both sides.
F150Traveller
Apr 1, 2015 09:00 PM
5280
Jul 26, 2014 02:29 PM
ungerp
Jul 8, 2014 09:57 PM
Marketmanohyeah1
Feb 23, 2014 01:08 PM
chriscrna
Jun 26, 2012 03:36 PM
