Aerostar Ford Aerostar
proportioning combo valve replacement
Old Feb 12, 2014 | 09:47 AM
greenaero96's Avatar
greenaero96
cant drive 96aero cause cant find a proportioning combo valve.Is there any help for greenaero
Old Feb 12, 2014 | 05:50 PM
xlt4wd90's Avatar
xlt4wd90
Isn't the proportioning valve part of the master cylinder? That should be readily available.
Old Feb 13, 2014 | 01:08 AM
96_4wdr's Avatar
96_4wdr
separate units on the 96. NLA and NL rebuilt by anyone.
take the old one apart and clean it. collection point for water, hair *****, corrosion in the system.
careful with the rubber plug and cap on the end, high pressure spring inside, disappears in the engine bay. don't ask how I know, 1st time years ago when I still could see.
Old Feb 13, 2014 | 09:45 AM
aerocolorado's Avatar
aerocolorado
Available as rebuilt unit from site sponsor Rock Auto. (A1 Cardone part # 122028, $115.60 plus $50 core charge).
Easy to get off but higher degree of difficulty to replace. Pull the rear brake line as far forward as possible without bending and start threading the line by hand to the RABS unit. Really easy to cross thread and ruin your expensive unit.
Also difficult to bleed the unit afterwards. Don't be surprised to see the "Antilock" warning light come on and stay on. Repeat bleeding process until light stays off with engine running.
Mine still comes on occasionally when driving for no apparent reason, then goes off a few minutes later.????
Even with the "Antilock" light on, the rear brakes still work normally, just the antilock function is disabled.
Old Feb 15, 2014 | 05:16 PM
96_4wdr's Avatar
96_4wdr
that's the RABS rear brake hydraulic pressure pulsation unit. Pulses the rear brakes when loss of braking is detected. Controlled by the RABS controller.
Brake combination valve.
The brake combination valve consists of two sections: rear proportioning, and an interconnecting pressure differential shuttle. The rear proportioning valve reduces pressure at the rear brakes to avoid lockup. The pressure differential shuttle is a bypass feature that allows full application of rear brake pressure when front system pressure is significantly reduced.
92 Aerostar. Air bag & brake system questions. - Ford Explorer and Ranger Forums "Serious Explorations"®
they often corrode severely inside from water sucked up by hygroscopic brake fluid.
be careful removing the end nut, heavy spring pressure inside.
NOT OUR COMBO VALVE, CORROSION DAMAGE EXAMPLE ONLY
Old Mar 9, 2014 | 10:20 AM
92Ranger123's Avatar
92Ranger123
greenaero96 - my '93 was leaking out that back plug, got a replacement for like $8 at Pick N' Pull, no issues since. Definitely a boneyard item IMHO. I think they rarely go out,
92Ranger
1960fordf350
Jul 12, 2018 09:36 AM
goose213
1978 - 1996 Big Bronco
Nov 22, 2004 03:12 AM
sunbird02
Aerostar
Aug 8, 2003 04:50 PM
Avanti
Aerostar
Apr 23, 2002 04:52 PM
bluechow
Dec 4, 2001 03:57 PM
