deleted
Old Feb 11, 2014 | 06:53 PM
64f100sixcylinder's Avatar
64f100sixcylinder
deleted
deleted
deleted
deleted
Old Feb 11, 2014 | 07:00 PM
dman2008's Avatar
dman2008
Nice work, but why were you disappointed? These trucks are 50 years old and will have bondo, lots of people use it but hopefully it's at a minimum.
D
Old Feb 11, 2014 | 07:03 PM
Becky_is_a_66's Avatar
Becky_is_a_66
I don't know if it will make much difference, but it looks like you are a water drain hole short in the last photo. If I remember correctly there are 4 drain holes along the bottom on each door; can only see three.
Old Feb 11, 2014 | 08:47 PM
64f100sixcylinder
deleted
deleted
deleted
Old Feb 11, 2014 | 08:54 PM
64f100sixcylinder
deleted
deleted
deleted
Old Feb 21, 2014 | 09:35 AM
bb65f1004x4's Avatar
bb65f1004x4
Looks like you did well. Just a little info if you don't know, The body work you found was the "correct" way of doing things for a long time. Most shops thought that the ooze through the holes kept it held on. I have ran into that before and instantly thought a had bought a jerry rig and didn't know what else I would run into. But it's all good.
Old Feb 21, 2014 | 10:02 AM
daveengelson's Avatar
daveengelson
An area I think is subject to rust is the leading edge of the hood so I drilled relief holes thru the lip on the underside of the hood at points where water tended to collect.
Old Feb 21, 2014 | 03:45 PM
64f100sixcylinder
deleted
deleted
deleted
Last edited by 64f100sixcylinder; Feb 23, 2014 at 03:22 PM. Reason: deleted deleted
grogreen
Mar 6, 2019 05:50 PM
A/Ox4
2015 - 2020 F150
May 1, 2018 02:33 PM
wildfire67
Nov 7, 2017 03:12 PM
john72ss
1983 - 2012 Ranger & B-Series
Apr 16, 2011 09:29 PM
FarmLaw
Garage & Workshop
Mar 24, 2007 11:29 AM
