Sponsored by: Real Truck
fuel problems i think
Old Feb 11, 2014 | 03:20 AM
dann167's Avatar
dann167
Got a 99 F450 7.3 with 190k miles, started acting sluggish. When cold, it wouldn't stay running, almost as if out of fuel. Would stall out when you pressed and released the accelerator but would idle fine. Now, it won't even stay running. Still acts like it's out of fuel. Changed the air filter, fuel filter, and added injector cleaner and conditioner. What else could it be? after warming up when shifting gears and letting off throttle it stalls and when restarted lets off blueish white smoke.
Old Feb 11, 2014 | 05:36 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE, dann167.
Fuel pump or Idle Air Control (IAC) valve are 2 possibilities that come to mind.
Old Mar 2, 2014 | 06:59 AM
dann167's Avatar
dann167
1999 f450 7.3
i changed the fuel pump and filter cleaned the tank out got it to run but once the rpm hit about 2200 the truck would start acting up and i would have to let off the throttle
dougcepress
Modular V10 (6.8l)
May 10, 2016 04:12 PM
IHdieselfan
Nov 20, 2011 08:41 PM
paddler
Apr 6, 2009 03:04 PM
steve450r
18
Jan 24, 2007 11:13 PM
denangme
Sep 23, 2005 09:46 AM
