Electronic locking rear questions
Old Feb 10, 2014 | 07:28 PM
swanee's Avatar
swanee
Thinking about getting a new truck. Currently have a regular cab short bed with 3.7 and non limited slip rear. I have to say I am pretty happy with traction control. In my old 2006 F350 with limited slip I used to have to put it in four wheel drive just to get up my driveway with a couple of inches of snow. That's no longer the case. While I wouldn't mind having the ELD for $400.00, but I am starting to think it just isn't necessary. Is there any downside to the ELD that I am not aware of. Appreciate any input.
Old Feb 10, 2014 | 08:12 PM
QwkTrip's Avatar
QwkTrip
Ya, the drawback is it doesn't stay in to high enough speed. Not useful except from a dead stop. If I did it all over again I would get the clutch posi (or whatever it is called).
I have read about swapping out the control module and **** on dash with a Raptor model to keep the locker engaged to something like 70 mph. It was expensive though.
Old Feb 10, 2014 | 08:17 PM
swanee's Avatar
swanee
The only way you can get limited slip now is with heavy duty payload 3.73 if I am not mistaken.
Old Feb 10, 2014 | 08:21 PM
QwkTrip's Avatar
QwkTrip
I have Tow Max so maybe I was given more choices than the average Joe.
Aftermarket can solve that problem too.
Old Feb 10, 2014 | 08:26 PM
swanee's Avatar
swanee
So do you push a button, turn a ****, or is it automatic?
Old Feb 10, 2014 | 08:36 PM
QwkTrip's Avatar
QwkTrip
I turn a **** for 4wd, and pull on that same **** for the locker. Locker works in 2wd and 4wd. I've heard a rumor some years/models can't use the locker in 2wd. I have a 2012.
I use the locker several times a week in 2wd for stoplight sprints. I have to use 4wd if leaving off the converter or the tires will spin even sitting still on the line. The rear brakes alone can't hold the torque of the Ecoboost with 3.73 gears.
Old Feb 10, 2014 | 08:52 PM
swanee's Avatar
swanee
Are the the stoplights in your neck of the woods slippery, or do you just like to drive?
Old Feb 10, 2014 | 09:49 PM
QwkTrip's Avatar
QwkTrip
It's part of my personal contribution to help Ford raise awareness about the Ecoboost.
My warranty will expire about the same time Full-Race finally releases a 600 HP twin turbo upgrade. What a nice coincidence!
Old Feb 10, 2014 | 10:55 PM
Pool Runner's Avatar
Pool Runner
Only downside is that it gets you stuck quicker, than just driving off-road with open rear. I don't know why, but I find if I'm off-road in 2wd, with locker enabled in sand or mud. It somehow makes the truck dig itself into a hole, even when not trying to horse around if that makes sense.
That said, I have found it most useful in unplowed snow. So far this year, I was in a snow storm with my truck. And since it's a super long 157" chassis, you have to plan way ahead when thinking about turning around. Especially when the streets are much narrow due to the snow and traffic driving by you.
Mad a 3 point turn into a sloped driveway, with about 6" of snow on the ground. Had the truck in 4wd which made it even more difficult to navigate. When I backed into the driveway, (rear part of the truck on the slope downward) the nose level. I found my self spinning one front wheel and one rear wheel.
The only way I got out of the situation was switching on the locking rear diff, which made forward motion a breeze after that. Part of the blame was the OEM Scorpion ATR's though, they might as well be slicks in the snow, but the locker helped immensely.
Old Feb 11, 2014 | 12:09 AM
TCAS007's Avatar
TCAS007
Explain the stoplight sprints.
Old Feb 11, 2014 | 06:26 AM
Robbgt's Avatar
Robbgt
The times I've used my ELD are more to "play around" then to actually free myself from being stuck. We've got quite a bit of snow in this area, and I usually leave it in 4wd hi with the TC on. Downsides as mentioned, disables at 25MPH, could hurt you if wheelspin is needed to get you free. Also, this means you are already stuck vs a limited slip diff that might have powered you through the first time.
Old Feb 11, 2014 | 07:30 AM
PrinceValium's Avatar
PrinceValium
Hmm that would be if a tuner like Mike's @ 5 star would be able to remove the 25 mph ELD!
Old Feb 11, 2014 | 08:44 AM
Turbo Dog's Avatar
Turbo Dog
I prefer the ELD in my new truck vs. an Eaton limited slip in my old truck. The old truck would make the rear slip in snow if it did a hard downshift going up a hill. The new truck shifts smoother and the rear end doesn't break loose because it isn't locked. The ELD isn't needed at speeds above 25 mph (other than for play times), it is useful for getting unstick or going over large rocks which leave a wheel hanging in the air.
Old Feb 11, 2014 | 11:55 AM
cartmanea's Avatar
cartmanea
Agreed, I see no disadvantage to having the ELD. It's not needed above 25, so that limitation shouldn't be an issue. Why would you need it above 25 except for horsing around? I loved the ELD and switch on the fly 4x4 when we had our two snow storms this year, and the traction control worked great too. On slick roads though, except to get going you want an open differential so one tire maintains contact and you don't have your whole rear end slip out.
Old Feb 11, 2014 | 06:45 PM
itguy08's Avatar
itguy08
What I don't get is why it's good for 25 MPH in 4Hi and something ridiculous like 60 MPH in 4Lo...
