Power steering help
Old Feb 10, 2014 | 05:56 PM
51 F3 owner's Avatar
51 F3 owner
Power steering help
Help, I have a 51 F3 that I'm in the process of restoring, I have done some research on power steering options, all the options are for the F1, are any of the power steering options out there compatible with the F3, or if there is a kit out the for the F3, any help is much appreciated, Thank You
Old Feb 10, 2014 | 06:59 PM
51PanelMan's Avatar
51PanelMan
F1-F3 shares the front suspension. Only difference are the brakes and hub. Steering is the same. Toyota power steering will work just fine in your F3.
Old Feb 12, 2014 | 07:08 PM
51 F3 owner
Thank you 51panelman, I was not sure if they were the same, I was looking into the rack and pinion for the straight axle due to the clearance for headers, but was told the front ends are different, I will look into the Toyota steering box, Thank You again
Old Feb 12, 2014 | 09:55 PM
Indiandave's Avatar
Indiandave
Check out Midfifty, they just came out with a replacement for the toyota, conversion. not sure if it will work on the F1, I was looking at the kit for my 56 f100
GearheadDiva
13
Dec 17, 2022 12:40 AM
wogden
Dec 11, 2016 12:45 PM
hulleywoodworking
May 23, 2015 09:16 PM
hippykiller56f100
26
Feb 20, 2008 05:18 PM
mikesfordf1
Feb 13, 2005 02:07 PM
