Ok , I'm looking for a replacement for my crappy worn out ford 4speed I believe it's a t170ft . A couple of weeks ago it started making some really bad noise . My options are to rebuild or to replace. I do work the truck a good amout so I would want somthing strong . I have red some post on how the t170 is a week pos . My ? Is what would be a derect replacement for my truck that has a 302 efi . I was thinking a t18 or t19. Would they work? Plz help thx alot
Your tranny if it's the model you suspect it is, had overdrive. The t18 and t19 do not have overdrive. Take your truck and drive it on the interstate with your tranny in 3rd gear. How do you like this? If you don't you need to stick with a overdrive tranny like a 5 speed. If you don't mind it, then you can install a t18 or t19.
Here's some more info on the 4 speed overdrive tranny.
