Replacement for a code b trans
Old Feb 10, 2014 | 12:06 PM
Peavey1986's Avatar
Peavey1986
Ok , I'm looking for a replacement for my crappy worn out ford 4speed I believe it's a t170ft . A couple of weeks ago it started making some really bad noise . My options are to rebuild or to replace. I do work the truck a good amout so I would want somthing strong . I have red some post on how the t170 is a week pos . My ? Is what would be a derect replacement for my truck that has a 302 efi . I was thinking a t18 or t19. Would they work? Plz help thx alot
Old Feb 10, 2014 | 07:51 PM
Franklin2's Avatar
Franklin2
Your tranny if it's the model you suspect it is, had overdrive. The t18 and t19 do not have overdrive. Take your truck and drive it on the interstate with your tranny in 3rd gear. How do you like this? If you don't you need to stick with a overdrive tranny like a 5 speed. If you don't mind it, then you can install a t18 or t19.
Here's some more info on the 4 speed overdrive tranny.
http://www.advanceadapters.com/tech-...-transmission/
Old Feb 10, 2014 | 08:35 PM
Peavey1986's Avatar
Peavey1986
Yes I don't mind not having over drive. So a t18 would bolt right in? I don't need any adapters? Thx for the help
Old Feb 10, 2014 | 08:43 PM
Peavey1986's Avatar
Peavey1986
Also the truck is 4x4 will the transfer case be a problem? It is mounted right to the trans
Old Feb 10, 2014 | 09:39 PM
ctubutis's Avatar
ctubutis
You'll need a T18 or t19 that came with the 4WD due to output shaft size differences.
Old Feb 10, 2014 | 09:42 PM
Peavey1986's Avatar
Peavey1986
Ok cool, I found a t18 out of a truck that had 50,000 miles on it for 250$. It had 4x4 . It will be my fist trans swap . Any advice?
Old Feb 10, 2014 | 10:38 PM
ctubutis's Avatar
ctubutis
The way I've done it:
1) Remove the transfer case
2) The transmission can come out using a floor jack
3) A transmission jack is necessary for reassembly, that shaft needs to fit into that hole (no comments, please ) and minute adjustments are necessary
jraiten
1978 - 1996 Big Bronco
16
Oct 15, 2014 10:01 AM
joeskyline06
Jan 26, 2009 05:02 PM
DECass
Jun 12, 2005 11:03 PM
brmal2
Sep 27, 2003 03:37 PM
Mike Davis
Jul 9, 2002 09:19 AM
