1978 - 1996 Big Bronco
i got no spark
Old Jun 29, 2003 | 03:18 PM
BroncoBlasta's Avatar
BroncoBlasta
Angry i got no spark
(((((((((((( help )))))))))))))))))
ok people i have a 87 bronco with the 302
i was driving one day an my truck just shut off an has not started for 4 weeks now it has no spark but it will turn over with no problem but just no start an i have put in a bunch of new stuff an still nothing what can i do this is driving me crazy on why it wont start (((((((((((((help))))))))))))))!!!!!!!!!!!!!!!!!!! !!!!
NEW STUFF:
coil
distributor
cap
rotor
plugs
wires
ecu (computer)
ignition mod
whats else is there to do i was told the crankshaft senser or the ignition switch but i dont know
thank you nete ( broncoblasta ) E-MAIL ADDRESS deadlyduo1922(No Email Addresses In Posts!)
Old Jun 29, 2003 | 04:12 PM
blue88EB's Avatar
blue88EB
i got no spark
Does you engine have a good ground? Because it sounds like you have replaced pretty much everything on the other end.
Old Jun 29, 2003 | 07:05 PM
fordnut74's Avatar
fordnut74
i got no spark
If you haven't yet, buy yourself an EVTM (electrical vacum troubleshooting manual)from Helm industries and start doing some wiring checks. This manual is a must have for any electrical anything on a rig. sounds to me like you may simply just have a loose or broke electrical connection. This manual will tell you troubleshooting tips, voltages, plug locations, pinouts, wire colors, and everything else. I have used them many times. Also the crankshaft and camshaft position sensor are one in the same on these motors and is called the hall effect sensor in the distributor, which should have been replaced with the new dist.
the deepsouth
Site Announcements
Apr 8, 2017 04:29 PM
misfitmedic
New Member Introductions
May 2, 2016 02:50 PM
ultraranger
40
Apr 18, 2016 04:44 PM
rebelford
Nov 20, 2005 07:10 AM
Redstallion4x4
Jan 8, 2002 09:22 PM
