engine stalled out after pulling out of driveway
Old 02-09-2014, 03:24 PM
'02strokerpilot's Avatar
'02strokerpilot
'02strokerpilot is offline
I just started and drove my truck down the street, acted like it was running out of fuel and stalled out. The fuel light was on so I put a couple gallons in the tank. Primed the fuel bowl and its spraying out of the drain valve when I open it. Truck acts like it wants to start but wont stay running long enough to hit the pedal. Its about 1qt low on oil. Any help would be great, I hope its not hpop! Maybe the lpop? It leaks at the seal down there and has for years.
Thanks
Old 02-09-2014, 03:51 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
Try cranking it more. You can hold about 1/4-1/2 throttle when cranking too. You may just have air in the fuel rails. sounds like you have good fuel pressure, but you may want to check it too.
BTW, a couple gallons of fuel in these tanks is not more than an 1" of fuel.
Old 02-09-2014, 03:57 PM
jetdoc's Avatar
jetdoc
jetdoc is offline
My front crank seal leaked as well. It contaminated the CPS connector, I'd check that.
Old 02-09-2014, 04:05 PM
'02strokerpilot
Thanks, got it started and filled up the tank. Still running a little rough so im going to change oil/ filters now. I just rebuilt the hpop line connectors a couple weeks ago and put new fuel filter in it at the same time. I haven't checked the hpop res to see if its staying full. I will check out the cps connector while im under the truck.
kupiec20
21
11-28-2017 10:49 AM
bruno2
07-03-2015 06:37 PM
southern79
35
10-15-2010 06:29 PM
bubbagilkes
10-13-2009 08:45 PM
fishnfry
06-04-2006 10:59 AM
Quick Reply: engine stalled out after pulling out of driveway
