85 F250 beater
#61
#62
#63
#64
OK. so I found a replacement cable, and I had about an hour after work and before dark to install it today so I did that, and transferred the drive gear and the O-ring over to the new cable. still no speedometer. Drove around the block and I have no odometer either...
so I was wondering if the cruise control might be something that could be interfering? I have a pic of it here with the new cables installed.
Also... as I sit here pondering I realized that I forgot to tighten the bolt down where the cable enters the tcase.
stupid misstep but could that be the issue?
and lastly, here is a pic of the rear bumper. what is this used for?
#65
okay. so tightened up that bolt today. that wasn't it but it needed it anyway.
I took the cables off the cruise control (I'm assuming that is what it is) and twisted the upper to see if it even made the speedo needle jump. it DOES! so my question, is it possible to install the cables to the cruise backwards? if not then I may have to return my cables and just get the "no cruise" version and see if that works.
#66
#67
#68
#69
Alright so... I just got my new gear in. I went and took the old one off and this happened... that's the old drive gear with the brand new cable. Any idea what happened? All I did was install the cable, backed up and drove forward to see if the speedo would move. that cable bit is jammed in too. I couldn't pull it out with pliers.
#70
Looks like the cable was either defective or it got kinked or pinched somewhere. The transducer (for the cruise) spins through okay right?
I did something similar to my '69, cable came in contact with the exhaust and self-destructed shortly after putting it in. I went back to the store I got it from and they warranty exchanged it, no questions. Might be worth a try.
#71
#72
#73
A quick search yielded some good info on this:
https://www.ford-trucks.com/forums/7...ml#post6075785
https://www.ford-trucks.com/forums/1...ing-wrong.html
https://www.ford-trucks.com/forums/1...rd-shifts.html
https://www.ford-trucks.com/forums/1...owing-mpg.html
https://www.ford-trucks.com/forums/1...djustment.html
#74
#75
