Ok heres something new, replace sending unit in my truck now it only registers to 1/2 tank, when i fill the tank the gauge reads empty, as fuel runs low is reads backwards ( new sending unit from LMC , front tank 19 gal.) Any suggestions?
plug and play sender, sender looks exactly like what was pulled out except the new one has all the tubes in place (not rotted off) ordered for 86-92 f250
Wiring 'wrong' wouldn't change the ohms to ground.
The gauge is reading backwards because the wrong one was ordered or LMC is sending the wrong stuff in the right box, again.
