Brake light style question
Old Feb 8, 2014 | 09:43 PM
taxgod4u's Avatar
taxgod4u
I have a 2013 FX4 with the smoked out head lights and tail lights from the factory (no chrome). The brake light assembly has a quarter inch trim around it that is clear palstic with kind of a prismatic bevel on the back side. I assume to be reflective. To me it just looks to "bright" next to the dark paint and dark tail light.
Has anybody done anything to black out or tone down the clear exterior outer ring?
Old Feb 8, 2014 | 11:16 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i believe many have painted the small clear section from the back side. painting it black makes it all "blend" much better.
Old Feb 9, 2014 | 12:31 AM
taxgod4u's Avatar
taxgod4u
thanks, any idea if you can separate the clear lense from the opaque backing to get in there?
Old Feb 9, 2014 | 12:35 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
no i believe you can get to the outter edge without any issue after you pull the taillight, if your talking about a different part then i'm totally off base.
Old Feb 9, 2014 | 09:35 AM
NASSTY's Avatar
NASSTY
I used VHT Nite Shades on mine. Although you can't tell from the pic... I taped off the brake light area and went with fewer coats than I did on the cargo light portion. I lost some brightness on the cargo light (which I wasn't concerned about) but my brake light still is as bright as stock.
Old Feb 9, 2014 | 12:01 PM
taxgod4u's Avatar
taxgod4u
Thanks Nassty! It looks great
That sounds like the plan!
Old Feb 9, 2014 | 12:55 PM
NASSTY's Avatar
NASSTY
I've seen Nite Shades look a little dull looking over time. So after the Nite Shades I clear coated it and wet sanded and buffed it as well. Of course I also removed the brake light before the whole process. I hate overspray on my paint.
Old Feb 9, 2014 | 01:36 PM
taxgod4u's Avatar
taxgod4u
good thought, any particular clear coat?
Old Feb 9, 2014 | 03:37 PM
NASSTY's Avatar
NASSTY
Not really, I think I used Duplicolor spray can clear.
I'm not usually a big fan of spray can clear. Normally I use 2 part clear coat and my spray gun. But I figured spray can clear would be good enough for this project. It's held up well for about 2.5 years so far.
Treacy
Mar 13, 2019 09:02 PM
the_auto_tech
2009 - 2014 F150
19
Aug 9, 2015 06:43 PM
cbzdel
Mar 6, 2012 07:56 PM
bhmudder11
Appearance & Dress-Up
Feb 6, 2009 06:45 PM
Jag Red 54
29
Jun 14, 2005 05:13 PM
