Throttle sticking at idle while running
Old Feb 8, 2014 | 04:05 PM
69'er's Avatar
69'er
I overhauled the 390 in my 69 F-250 and installed a new (rebuilt) 2 bbl Autoline carburetor. The problem is that when it's running the linkage is sticky and won't return to the dashpot very easily to idle down. When the motor is not running it works fine. It's well lubricated. Any thoughts on this?
Old Feb 8, 2014 | 04:39 PM
HIO Silver's Avatar
HIO Silver
Could be the throttle plates are binding/rubbing against the bores. Pull the carb and take a look... there shouldn't be any shiny spots.
You do have a carb return spring, right? Double is better by the way.
Old Feb 8, 2014 | 04:41 PM
MIKES 68 F100's Avatar
MIKES 68 F100
check your choke , it has a separate fast idle adjustment
Old Feb 8, 2014 | 05:00 PM
69'er's Avatar
69'er
Thanks for the replies. Yes, the return spring is there and is a fairly stout one. I did look for another one this morning with no luck. Would the plates bind only when the motor is running? That's what has me puzzled. It all works and feels fine when it's off. It's only when it's running that it gets a little stubborn about that last 1/8 - 3/16".
It's a manual choke Mike and the fast idle isn't engaged when this is going on. I looked at that also.
Old Feb 10, 2014 | 12:46 PM
JEFFFAFA's Avatar
JEFFFAFA
How 'bout that pivot assembly bolted to the intake in the throttle linkage between the firewall and carb. Is it worn out? Binding? I'd get a one piece link off a Dent and delete the pivot. Hio's got some pics if you need to see what I mean.
Old Feb 10, 2014 | 01:12 PM
69'er's Avatar
69'er
Interesting you should mention the one piece link Jeff. I actually found one in my old parts and almost cut it into a new piece for the pivot type linkage. When I held it next to the old linkage I saw it could work and even be more adjustable.It was a part of that pivot linkage that was hanging up but I used a welding rod and shaped a new piece instead and it's now working great. Still wonder why it only did it while running tho. I found it by disconnecting that section while it was running. I'm hanging on to the one piece linkage though- just in case! Thanks for the reply.
Old Feb 10, 2014 | 03:08 PM
JEFFFAFA's Avatar
JEFFFAFA
You're welcome. The reason why Ford did that pivot is so the lifting of the engine if the L/S motor mount broke wouldn't create the linkage opening up the throttle on the carb. I would still go the one piece route if it were mine.
And BTW, Welcome to FTE!
Old Feb 10, 2014 | 04:23 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by JEFFFAFA
How 'bout that pivot assembly bolted to the intake in the throttle linkage between the firewall and carb. Is it worn out? Binding? I'd get a one piece link off a Dent and delete the pivot. HIO's got some pics if you need to see what I mean.
Here ya go. This one is outta my Mustang parts bin. I recently replaced it with the ballstud & clip style off a 78/79 Dentside.:
Old Feb 10, 2014 | 06:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/72 F100/350 V8's have a bellcrank (7A185 in upper parts catalog pic) located on the left rear corner of the intake manifold that the accelerator pedal and carb linkage connects to.
It has bushings that cannot be replaced. When the bushings wear and/or crack apart, the linkage is sloppy or binds up.
C7TZ-7A185-A .. Bellcrank Assy / Obsolete
A/T & M/T applications: 1967 F100/350 352 / 1968/69 F100/350 360/390.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
KAHOKA MOTOR CO. in Kahoka MO has 1 = 660-727-2181.
PARTS INTERNATIONAL in Farmers Branch TX has 1 = 888-727-0418.
Old Feb 10, 2014 | 06:36 PM
NumberDummy
Double post.
Old Feb 22, 2014 | 08:24 AM
69'er's Avatar
69'er
Thanks Bill and Jeff. Sorry I didn't reply earlier but wasn't aware anyone had posted here. That looks like the linkage I found in my old parts. It probably came off my old 68 that had the 240-6 in it. I held it alongside the other linkage before and it will work. I'll probably swap it out soon after reading what you've written about the other type that I'm currently using. It does seem to hang slightly still. I'm posting about yet another problem with this carb that maybe you can help with also. Thanks again for your replies- they've been very helpful!
Old Feb 22, 2014 | 12:07 PM
JEFFFAFA's Avatar
JEFFFAFA
On behalf of Hio,Bill, and myself I'll say You're Welcome! Thank You for the closure of this thread. So many just drop it and don't tell us the outcome of their problem or question.
Old Feb 22, 2014 | 02:32 PM
69'er's Avatar
69'er
I like to see them closed too Jeff. They're good sources for people having the same problem. I did it with the previous one also and started the new thread with a separate problem for the same reason- so they can be searched with the solution attached to them.
Old Feb 22, 2014 | 02:55 PM
JEFFFAFA's Avatar
JEFFFAFA
ZZZACTLY! Good Job.
DieselDrake
May 23, 2014 11:59 AM
D_T
Aug 8, 2011 07:26 PM
CropDusterMan
Feb 4, 2011 05:07 PM
1954F250
Sep 4, 2008 11:11 AM
gadams
Mar 13, 2001 02:10 AM
