Navigator won't go.
Old Feb 8, 2014 | 12:27 PM
Jack T.'s Avatar
Jack T.
Navigator won't go.
Bunch of searching, and haven't found an answer to my particular set of problems.
2000 Navigator 4x4. Wife drove it to work (2 miles) yesterday. Came out of work last night. . .and the car won't move. None of the forward gears work, reverse doesn't work, and switching from A4wd to 4wdH to 4wdL doesn't make any difference.
The OD light on the stalk isn't lit, and nothing happens when you push the button.
Gear selector moves like normal. It *feels* normal. But gears don't engage.
I swapped the filter this morning. Under the car (with the engine off) I can hear things moving around when she shifts gears.
It has been shifting hard from 1st to 2nd for a few months.
She said she didn't notice anything wrong yesterday when she drove it. . .no bangs, no jolts.
We do have snow/ice on the ground. . .read something about maybe the transfer case is in neutral? Any way to check/fix that?
Would the solenoids suddenly go bad AND would that cause none of the gears to engage?
Obviously I'd like to avoid having it towed to a transmission shop. . .anything else I can check/try before that?
Old Feb 8, 2014 | 01:40 PM
wastingas's Avatar
wastingas
Did you check the fluid (running up to temp, while in park?)
As far as the transfer case being in neutral I think it stays in what ever gear you left it in. It shouldnt go into neutral when you shut it down. What do you mean by it it feels like its going into gear. RPMs lower truck bumps fwd a little?
Old Feb 8, 2014 | 01:48 PM
Jack T.'s Avatar
Jack T.
Transfer case: I just wondered if maybe (auto-4wd) it was in the middle of switching from 4wd to 2wd (or vice versa) when she killed it. . .
RPMs don't change, but the shifter *feels* like it should. Meaning I don't think it is a linkage problem.
Old Feb 8, 2014 | 03:42 PM
alloro's Avatar
alloro
There is no neutral in the t-case, it is always engaged. What happens when you step on the gas? Does it rev like it's in neutral, or does it act like it's in gear and your foot is on the brake?
Old Feb 8, 2014 | 03:47 PM
Jack T.'s Avatar
Jack T.
Revs like it is in neutral.
Old Feb 8, 2014 | 06:25 PM
alloro's Avatar
alloro
When in Drive, can you push the truck and make it move or does it seem like it is still in Park?
Old Feb 8, 2014 | 07:51 PM
Jack T.'s Avatar
Jack T.
We'll check tomorrow. . .it's not here at the house.
I'll let you know.
Old Feb 9, 2014 | 10:30 AM
Jack T.'s Avatar
Jack T.
I'll let you know.
With the shifter in reverse, we can push and move the car.
Old Feb 9, 2014 | 01:00 PM
alloro's Avatar
alloro
In that case the linkage is all good and you've pretty much confirmed that it's either an internal tranny issue or the torque converter broke.
Old Feb 9, 2014 | 06:35 PM
Jack T.'s Avatar
Jack T.
Well foot. Guess it'll get towed to a transmission shop.
Thanks for the assist!
dodonne2
Oct 10, 2025 04:34 AM
inthealders
Feb 8, 2016 05:52 AM
klank2000
1997 - 2003 F150
Aug 28, 2011 10:46 PM
mklemin
May 4, 2008 09:52 PM
gimps
Dec 7, 1999 07:40 PM
