2003 Ford F250 6.0L oil pump failure
^ that and do you mean what would it cost for someone else to do it, or what would parts cost to do it yourself? I assume yourself since you ask about tools needed.
Honestly a simple socket set is all that would be needed to do the work, maybe a screw driver here and there.
Parts cost will greatly depend on the hpop or lpop, and what sort of injectors you go with (rebuilt, new, aftermarket).
Needs the following:
-Oil Pump
-Two Injectors
-Oil Cooler
I just wanted to know what it would cost to do the job with new parts, before buying the truck.
Thanks
If its the high pressure oil pump..thats around $600, hopefully its that, pretty common with a 2003...low pressure, not entirely sure but i know its 1 or 200. Id be worried if it was the low pressure
Injectors are 220 each
Oil cooler kit is around 300
Also need intake manifold gaskets, hpop cover gaskets (not sure if it comes with hpop? if thats the case) and whatever else you run into. Could be a good deal depending on the trucks condition, and what the rest of the engine is like. How many miles?
I would be willing to bet if the guy only wants 2900 bucks it probably has more problems than he is letting on, more like needing the engine rebuilt and or bad transmission.
2003 F250
293k original miles.
2003 F250
I run a 3 bay auto repair shop in Orlando Florida i was thinking of buying and fixing when i am slow depending on the repair cost.
2003 F250
Thanks i will make the offer and see what happens, thanks. A question i was working on a 2006 F250 POWER STROKE 6.0 the cat was plugged here in orlando no emission test cleaned out the insides of convertor the truck runs good do i need to replace a new cat.
Ford F250 low oil pressure
