steering binding/sticking
Old Feb 9, 2014 | 08:40 PM
senix's Avatar
senix
Originally Posted by Tofan
Nope they stopped doing hydro on the 350s since 2011. Started sometime late 2011 in the 2012s I was confused about this as well.
So guess it is just the DRW's with hydro now.
Old Feb 10, 2014 | 11:52 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Yes, only DRW's with Hydroboost. 2011 SRW F350's have it as well.
SultanGris, can you hear any noticeable noises when it does this? If so, what does it sound like?
Based on what you have mentioned so far in this thread, I am guessing it is your clock spring (just behind your steering wheel). Mine encountered the issue once too.
Old Feb 10, 2014 | 12:43 PM
69cj's Avatar
69cj
Originally Posted by SultanGris
Thanks.
That was another thought but I figured if it was that it would be on the same spot of the turn and happen every time if the gears were bad or something, perhaps that's what it is because everything u can see looks good. It's either in the column or the box. How many times did it happen to you before you figured it out?
I'm 2000 miles from home and going from Pheonix to San Diego tomorrow or Tues. Still under warranty but I ain't exactly got time to make an appointment. Maybe I'll stop by tomorrow and see how busy they are. Hate for it to let loose going 75mph, heh.
When it totally locked up in a turn and I almost went over the curb.
Old Feb 10, 2014 | 02:53 PM
SultanGris's Avatar
SultanGris
No noise. Just got back from dealer. They couldn't find anything, I knew they wouldn't, but they didn't take column apart. Said steering is hydraulic. Guess I'll see if it happens again. Strange.
Old Mar 13, 2014 | 01:07 PM
Badger Mike's Avatar
Badger Mike
I'm also having a steering issue, most noticable when turning left. The steering does not lock, but I can here a noise coming from under the truck on the drivers side. Tech can here it as well, but unable to diagnose so far. Any thoughts?
Old Mar 13, 2014 | 01:38 PM
SultanGris's Avatar
SultanGris
My issue has not yet reoccured. Happened like 3 or 4 days in a row. Very strange. Something must have been stuck or binding somewhere. I did kinda hear a bang or a pop once like something fell off and hit the street or something. Hasnt occurred since then. Dealer said they no no signs of anything rubbing or binding though, but they probably didn't look too hard.
Old Mar 13, 2014 | 01:58 PM
Badger Mike
Mine is more of a clunking noise coming from under the front drivers side. Again, turning left and/or going over a bump at the same time.
Old Mar 13, 2014 | 02:10 PM
OneTon350's Avatar
OneTon350
Originally Posted by marchare011
Possible binding u-joint in front axle?
X2
Mine was not recovering out of the turn like it should.
I had to "wheel" it back straight. Buddy of mine was having the
same issue, and a mech told him it could be the u-joints.
I looked at mine and there are grease fittings on the joints.
After a few time greasing them it hasn't done it in 2 years.
Old Mar 13, 2014 | 02:27 PM
Badger Mike
Interesting, mine has 9,700 miles on it, so hard to believe it's a bad u joint, but worth tracking down. The first time I had it in, they replaced a tie rod! I think they're as stumped on this as anyone.
Maybe if I call Ford they'll give me a new truck
Old Mar 13, 2014 | 02:29 PM
EpicCowlick's Avatar
EpicCowlick
Just throwing this out there but does the truck have an aftermarket steering stabilizer? If so, there is a bracket that when going over a significant bump can be pushed into the tie rod adjusting sleeve which will make the steering very stiff.
Old Mar 13, 2014 | 02:32 PM
Badger Mike
No aftermarket equipment on this truck, bone stock. (unlike my harley)
Old Mar 17, 2014 | 11:33 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by Badger Mike
I'm also having a steering issue, most noticable when turning left. The steering does not lock, but I can here a noise coming from under the truck on the drivers side. Tech can here it as well, but unable to diagnose so far...
I'd like to look into this to see how I can help, Badger Mike. For me to do so, I'll need a PM from you with your full name, best daytime phone number, VIN, mileage, and servicing dealership. I'll start researching ways to assist.
Crystal
Old Jul 28, 2015 | 01:03 PM
  #28
AMEC Electric LLC's Avatar
AMEC Electric LLC
At 86,000 miles mine is doing almost the same thing. Front End shop suggested serpentine belt or condition of fluid. He claims the pump is extremely high pressure and the fluid doesn't last long. He has seen this on others at his shop. Was thinking about changing the belt too.
Old Jun 2, 2016 | 07:14 AM
  #29
HOGSONTHEROAD's Avatar
HOGSONTHEROAD
Crystal
Hey Crystal, I'm dropping my 2011 ford f350 off next week at dealer to look at. Can you provide any assistance for me? PM if you get this. Thanks Rich
Old Jun 2, 2016 | 02:41 PM
  #30
FordService
Official Ford Rep
Hello HOGSONTHEROAD,
I replied. Please check your inbox when you get a chance.
Tricia
