Rear Main Seals
Old Feb 7, 2014 | 10:21 PM
fabieber's Avatar
fabieber
Rear Main Seals
Replacement of the rear main seals; is this a job that should only be done by a shop or can an amateur do it anticipated good results?
Engine is 239 V8 from my '55. Engine is out and on a stand. Clutch components are removed.
Also, any debate about rope type seals vs. neoprene?
I have some mechanical abilities but no recent experience. The last work I remember doing inside and engine was in 1965 on my 55 Ford car. My brother and I changed the connecting rod bearings without removing the engine, without checking the crank for needed repairs and without Dad's permission. Bearings lasted nearly a week!
Maybe I just answered my own question.
Old Feb 7, 2014 | 11:42 PM
smallello's Avatar
smallello
Are we there yet?
I am very interested in the response to this question. I have a 429 that needs the rear main seal replaced.
There are videos on you tube of people changing them without removing the motor and it seems like it can be done. Just have to have enough room to get the pan off.
If you already have the motor out you should be able to do it pretty easily.
Old Feb 8, 2014 | 10:39 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Unless you pull out the crankshaft (and therefore, all the rods and pistons), you can only do the lower half of the seal. I don't know if there is a neoprene seal option for Y-blocks or the 429's that doesn't require machine work, John Mummert's site would have them if there is one.
Getting rope seals installed isn't rocket science but results vary. I would for sure replace the lowers any time the engine is out and it's easy to pull the pan, for that matter pulling the pan is always worthwhile. I'd check a couple of main and rod bearings, note their sizes (marked on shells), possibly replace the oil pump too. Clean any sludge out of the pan.
Old Feb 8, 2014 | 11:16 AM
Steve's Avatar
Steve
You shouldn't have to remove rod/pistons. If you remove the main caps, you can slip the old upper half out and slide in the new one. Then you can set the lower seal in the retainer with the side seals. Make sure the mating surfaces for the lower retainer are very clean and dry, and put a tiny dab of RTV there before you torque it down. Inspect the retainer carefully to sure it's not warped. If it is contact John Mummert for a replacement.
Old Feb 8, 2014 | 02:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Unless the Y-blocks are real different than flatheads and other engines I've done, the upper rope seal isn't going to slide in or out. If it could, it wouldn't seal worth a darn. If you can raise the crank up enough with the rods attached, and figure a way to hold it, that would possibly work, but I don't see how you'd roll it into the groove fully.
Old Feb 8, 2014 | 02:19 PM
mechmagcn's Avatar
mechmagcn
I've done several rope seals in the vehicle where I force the old seal farther into the upper groove on both sides with a punch and then drive a short piece into the opening to take up the space. Put the lower seal in as usual and reinstall bearing cap. Never had one leak doing it this way. An older fellow showed me this many years ago.
Old Feb 8, 2014 | 03:32 PM
GLR's Avatar
GLR
Easy enough to do without pulling crank. Seal cap off, punch some on one side of the seal in block, sheet metal screw into the other end of seal. Pull on screw enough to expose one end of the seal so you can grip it with pliers to pull out. It helps to turn the engine as you pull on the seal. Installing - make sure the seal is really soaked in oil first. There are kits available. For example:
KD Tools 492 Oil Seal Remover/Installer - Amazon.com KD Tools 492 Oil Seal Remover/Installer - Amazon.com
Old Feb 10, 2014 | 01:56 PM
petemcl's Avatar
petemcl
Actually you can do the upper. I did it on a 1959 Ford V-8 Skyliner engine. When I bought the new rope seals I got an installer that was made of woven wire like Chinese fingers. After removing the old seal you just thread the wire over the crank, insert one end of the new seal into the Chinese fingers and then (and here is the trick) with the main plug wire removed so the engine won't start just pull down on the free end of the wire and bump the starter and the seal will pull through. This is obviously best done with a remote starter button or two people. Once the seal is through far enough to remove the Chinese fingers you can cut off the excess rope seal with a razor blade.
Don't ask me how long it took me to do it the first time until someone clued me in on bumping the starter.
Old Feb 10, 2014 | 02:29 PM
bra$$monkey's Avatar
bra$$monkey
Does no one own the right tool for the job?
The tool is called a sneaky pete - its a wire corkscrew looking tool that you twist into the rope seal in the top.
Drop the pan, pull the end cap & twist the sneaky pete (costs like $10) into the upper rope seal.
Pull it out.
Use a new neoprene 2 piece seal.
No joke here - make sure you have the new seal oriented correctly - there is a front & a back.
push the new upper half into the upper groove. Off set this seal about 1/4 inch. don't line it up with the cap - you want 1 end pushed in some & the other end sticking out some.
Use high temp RTV & put a blob on each end of the seal.
Put the second half in the rod cap you pulled & put the cap back in place - torque to spec.
new pan seal & you are done.
I've done this on an old 58 chevy stovebolt -- I was shocked at how easy it was - & the new type of seal will not leak!
Get the right tool though - check amazon, or online -they are everywhere.
Old Feb 10, 2014 | 03:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The tool linked by GLR is a Sneaky Pete. The corkscrew tool is a packing removal tool.
fusionstate
Apr 24, 2015 11:31 PM
MERC414
Feb 8, 2009 11:17 PM
daggerNC
Nov 1, 2006 11:42 PM
degdawgs
15
Jul 7, 2006 07:25 PM
jheroux
May 6, 2004 09:36 PM
