Sponsored by: Real Truck
Stainless brake system
Old Feb 7, 2014 | 06:52 PM
helirich's Avatar
helirich
I want to change out the whole system for stainless on a 2007 superduty. I got stainless lines and braded hoses for it. I'm ordering stainless fittings. (I got a flare tool) The braded hose kit i got has two hoses for the front and one drop hose for the rear. When I looked underneath the rear, I see the rear discs have a short hose that hooks to the caliper. Does anyone make them in stainless braded hose?
Also, stupid question. Does the front resivoir go to the front brakes? The reason I ask is the front fitting is smaller. Seems like the big fitting would go to the front.
Old Feb 7, 2014 | 06:57 PM
phillycincykid's Avatar
phillycincykid
i cant answer your question but this sounds like a bad *** idea i need to update my braking system come spring and would like to follow this.
Old Feb 7, 2014 | 07:02 PM
Snowseeker's Avatar
Snowseeker
For anyone looking to get away from rust I would suggest looking at NiCopp lines. I have been using them on our trucks and they have been holding up excellent!
Old Feb 7, 2014 | 07:04 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Only company who makes a complete five line kit is Russell, and they don't sell one or two lines separate...... And the reservoir is hooked to the master cylinder then there is a front hard line and rear hard line from that down to the front drivers fender that goes into the ABS block then from the block four lines come out and go to the wheels.....
Sent from my iPhone using IB AutoGroup
Old Feb 7, 2014 | 07:49 PM
helirich's Avatar
helirich
I wonder if I can return my lines. Anyways, about the reservoir, what I ment was the master has two fittings. Is the front one for the front brakes?
Old Feb 7, 2014 | 07:54 PM
jeepnford's Avatar
jeepnford
You might try something like Summit Racing or Jegs for stainless flex lines. I put all stainless on my old Jeep CJ a few years ago, the only difference was I bought pre-bent lines. I assume you have a flare tool for stainless?
Old Feb 8, 2014 | 09:36 AM
Monster-4's Avatar
Monster-4
I replaced my rear line with the same stuff. Super flexible and easy to work with. I recommend it as well. I would use NiCopper over stainless steel unless you are worried about looks. The stuff is so flexible it is hard to make a nice straight line, well at least for me.
Old Feb 8, 2014 | 09:45 AM
Snowseeker's Avatar
Snowseeker
Originally Posted by Monster-4
I replaced my rear line with the same stuff. Super flexible and easy to work with. I recommend it as well. I would use NICopper over stainless steel unless you are worried about looks. The stuff is so flexible it is hard to make a nice straight line, well at least for me.
It is great stuff to work with and personally I love the look of the copper lines!
I have used the stuff in a couple classic cars for customers and they as well loved it! One car got ALL of its hard lines replaced with it, trans lines, fuel lines, brake lines, and all.
It does take some time to make it all strait and pretty.
Old Feb 8, 2014 | 10:01 AM
MC5C's Avatar
MC5C
Keep in mind that stainless lines NOT manufactured by a DOT approved company to FMVSS specifications are not street legal. Sure, it's easy to buy the line and ends, and put together hoses - I do it all the time for my race cars. But it's illegal on the street. The biggest differences are the crimped hose ends and the strain relief on the hose ends. If you do this, buy from an approved manufacturer. BTW, stainless hose looks like crap after a few winters, same as everything else... It's only shiny when it's brand new.
Brian
Old Feb 8, 2014 | 12:32 PM
helirich's Avatar
helirich
The braded stainless hose I got has a clear cover over it and it is DOT approved. The stainless hard line I got will be flared by me. Are you suggesting that is not legal?
I have never seen the copper stuff. But I want this to be good for salt water. So I think I will stay with stainless.
Old Feb 8, 2014 | 01:49 PM
xmontex4's Avatar
xmontex4
Is there a place that sells a kit? I would love to do the same thing i just done have a flaring tool to do the ends myself. Love the idea man post up pics as you do it! PMF sells SS braided hoses i bet if you called them they might make some custom ones because they make them to order so it would bt that hard for them. Plus you can get colors lol.
Old Feb 8, 2014 | 03:10 PM
MC5C's Avatar
MC5C
I meant stainless braided flex lines need to be manufactured with DOT approval. I don't know about hard lines since I almost never use them. Doing the flares in stainless should be a treat, that is hard stuff to work with.
Brian
Old Feb 8, 2014 | 07:02 PM
helirich's Avatar
helirich
I got the flare tool from inline tube. It is a simple/cheap one. I have seen some that cost about 400. I think those do the flare while making you an drink. I have to go out of state for about a month. So I won't be doing this till I get back.
Old Feb 9, 2014 | 09:22 AM
Monster-4's Avatar
Monster-4
NiCopper is made from 90% copper and 10% nickel both of which are extremely resistent to the effects of corrosion by salty water. Trust me living in northeast Ohio I did some research on materials before replacing any brake lines. I think they will last just as long as stainless steel and have the benefit of being workable with regular brake line tools.
However, it sounds like you already have all the tools and materials for stainless so that would be the route to go.
Old Feb 9, 2014 | 01:28 PM
Snowseeker's Avatar
Snowseeker
Put up with rust? I do it every day! https://www.ford-trucks.com/forums/1...t-up-with.html
