After 25 years.. It has been rescued!
#31
Anyone with deep pockets can restore a truck but to find a unmolested truck and get it to drive down the road is VERY rare.
FordMan you have one cool truck !
#32
#35
Please give me your opinions on the truck, It has sat between two shops on a farm for 25 years. I know It's very rough, but I see it being fixable. I couldn't let it rot anymore. It will be a long road. I know the drive shaft is gone for some reason, and someone in the family thought it was funny to shoot the back window out..
Thanks guys!
Thanks guys!
Here are a few guidelines:
Preserve Sanity.
- Grab a trash bag and cardboard box… trash and garbage goes in the bag and any spare parts goes into the box.
- The owners manual and, if present, fuses goes in the glove box.
- Vacuum/sweep out the interior and sweep out the bed.
- Clear out drain holes.
- Powerwash the body, wheel wells, and even the engine compartment. Every nook and cranny. Crap falling into your eyes is no fun.
- Cleanliness is next to…
Evaluation/Visual Inspection.
Grab a note pad and do a bumper to bumper visual inspection.. this is also time to go on “Hack Patrol” – All those so-called “repairs” made by previous owners. Look for duct tape, household wire nuts, electrical tape, wood screws, wires that go to nowhere.
On the notepad make three columns/categories:
- Gotta fix/replace now.. these include safety items like lights and brakes, cab mounts;
- Gotta fix/upgrade/replace soon or “The Watch List” – floor pans.; and,
- Fix later – rust holes, old wiper blades, loose ***** and switches.
- Look for loose, missing, or broken hardware like lug nuts, fender and bumper bolts, and bellhousing to engine bolts. Feel around for soft or cracked hoses – radiator hoses degrade from the inside. Crimp it with your hand and it should have the same firmness all the way around.
Fluids and Filters
Change everything...Engine oil, coolant, auto trans, power steering, and brake fluid. If possible, front and rear axle lube, and gear lube in a manual trans.
Air up the tires and the spare.
Lube all grease fittings.
Fire It Up
New/known good battery
Full tune-up... plugs, wires, etc. and a carb rebuild kit. A spare starter solenoid is a good idea.
Rebuild the carb.
If the fuel tank is of unknown condition, run the fuel pump from a gas can.
.... have a fire extinguisher handy or "fire it up" may have a whole new meaning.
... from here on out it is really up to you. Personally, I like to verify the electrical systems as a matter of safety (lights, horns, etc.) and then start on brakes and steering.
Good luck!
#40
Have you tried turning the engine over yet?
I got a 78 Bronco right after Christmas that had set for 12 years without running and the oil pan off of it. It was locked up and full of dirt daubers in the bottom end. Filled each cylinder full of pb blaster until it was running out. I got it to start moving. Got all the dirt daubers out I could with air compressor. Oiled it from below with a oil can. Put it all together and it fired up. I've changed oil 3 times everytime I get 200 miles on it. Runs smooth as silk and burns no oil.
#41
Nice! No I haven't tried anything yet, the key has been lost. A set of blank keys are on the way I will have them cut when they get here! I need to see if any oil will drain, (I doubt it.) Put new plugs in, fresh oil, get a new belt, and get the carburetor going or buy a new one. Fingers crossed that it will start! Thanks everyone for the positive feedback it's great support!
#42
Hoooey that rig is crusty.
Preserve Sanity.
Fluids and Filters
Fire It Up
Rebuild the carb.
Good luck!
Preserve Sanity.
Fluids and Filters
Fire It Up
Rebuild the carb.
Good luck!
A ton of great info!! Thank you!
#45
I respect guys taking projects like this. In some places. Like here by us these trucks are not so common so getting an old truck like this one is very lucky. I think the rusty look gives it character. Even if you go for the respray option I can ensure you the day you drive it down the road for the 1st time all the work put into it will be worth it. Great find and good luck with your project. Looking forward to the build
