how many miles
Old Feb 6, 2014 | 09:35 AM
shademt's Avatar
shademt
how many miles
how many miles on your 7.3.? without major repair?
Old Feb 6, 2014 | 09:41 AM
SARDiverDan's Avatar
SARDiverDan
"major" repair is a relative term depending on who you ask. I have not had what I consider to be a major repair....yet Original owner, 150k miles, truck just over 12 years old
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I'm at 202k+ and the worst I've had has been 1 flat tire the o-rings in the hoses on my HPOP failed about 5 miles from home. Dumped a bunch of oil, but got home and under $100 to fix.
Old Feb 6, 2014 | 10:38 AM
HKusp's Avatar
HKusp
171,000 and change....let's see...Tranny replaced at 145,000 and gave absolutely no warning at all. Never ran it hot, had Schaeffers synthetic in it for 70,000 miles and it stopped working like I popped it in neutral. 150,000 miles and the injectors started going to the point that plugging it in, and using synthetic 5w-40 didn't help it by 163,000 miles so had to replace them.
And hey Brendan.
Old Feb 6, 2014 | 10:59 AM
thomabb's Avatar
thomabb
220k and counting. Never had the motor out. Factory tranny.
Old Feb 6, 2014 | 11:16 AM
F250_'s Avatar
F250_
My '02 F250... 252K, no major work.
My '03 Excursion... 185K, no major work.
My son's '02 F250... tranny rebuild at about 285K.
All injectors are original in all three vehicles.
Old Feb 6, 2014 | 11:20 AM
HKusp's Avatar
HKusp
Show off...
Old Feb 6, 2014 | 11:29 AM
mtdigger's Avatar
mtdigger
99.5 dually, 2nd owner 53,125 miles. Zero repairs. unless we're counting the vacuum lines to the hubs. I love this truck more with every passing mile oops, forgot the water pump at nearly exactly 50,000.
Old Feb 6, 2014 | 12:40 PM
F250_'s Avatar
F250_
Originally Posted by HKusp
Show off...
Yes, but I really don't get much credit for much of it. I've been extremely blessed, very fortunate, and remain very grateful. I guess I didn't realize how much differently your truck had behaved, and I expect that these types of differences are partially a result in manufacturing variances... sometimes they balance each other out, and sometimes they come together in a "perfect storm" as an anomaly.
Old Feb 6, 2014 | 12:55 PM
clem1226's Avatar
clem1226
Tranny at 220ish but other than that nothing. The motor has never had a valve cover off. Maintenance stuff like rebuilt the turbo at 370k a few water pumps and a few hp power steering lines. She romps pretty hard at 20 degrees or below with 15/40 Dino and not plugged in but always starts the first try. This winter I switched to Mobil 1 5/40 and this morning she started at 3*F as if she warm with out being plugged in. I know I am due for injectors because she gets pretty smoky with extended idle time but with the recent horror stories of injector swaps gone bad I am more inclined to let her go until it is absolutely necessary.
Old Feb 6, 2014 | 01:09 PM
GeorgiaBoy17's Avatar
GeorgiaBoy17
2002 7.3 at 159k miles and has had one transmission rebuild other than that, she's chugging along just fine😁
Old Feb 6, 2014 | 01:46 PM
blais42's Avatar
blais42
Less than 138k... still trucking. No major repairs.
Old Feb 6, 2014 | 02:08 PM
th67ss's Avatar
th67ss
339 & 1/2 with only ball joints and tires being the most money spent on my 03.
Old Feb 6, 2014 | 02:25 PM
helifixer's Avatar
helifixer
'97 4x4 5 speed 230,000 miles. water pump, glow plugs, front brakes 2 times. still on factory rear brakes.
'99 6 speed 2 wd, 330,000 miles, one cylinder takes about 5 minutes to start firing, after that runs like a champ. transmission changed around 300,000 miles due to a cooler line breaking and dumping all the fluid.
2000 excursion 180,000 miles, glow plug controller, water pump just started dripping.
Old Feb 6, 2014 | 02:39 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Most all diesel engine manufacturers define "major" as repairs where the head has to come off. If that is the case then none of our 7.3 trucks have had major engine work yet.
My personal pickup needed a transmission rebuild at 143,761 miles.
No under hood repair what-so-ever until 238,217 miles when one of the UVCH came loose. Shortly after that it went through a rash of items which I call the "quarter million mile stretch". I had two failed injectors, water pump, ICP sensor, serpentine belt tensioner fail all within 10k miles or so.
Been pretty good since. I had the power steering pump fail around 300k. At 322k now and things still look good. Still running the original starter, alternator, fuel pump etc.
My wife's truck has about 208k miles and I have only had to change the serpentine belt tensioner and alternator on that thing. Not sure what has been done by the previous owner though...It had 180k when we bought it.
