how many miles
Old Feb 6, 2014 | 02:53 PM
2000F250guy's Avatar
2000F250guy
247,XXX 1 bad ball joint so i changed uppers and lowers on both sides
245,XXX rebuild transmission
243,XXX HPOP seals started to leak
Power steering pump has been whining for 30K miles
Old Feb 6, 2014 | 03:08 PM
Nsaan's Avatar
Nsaan
Where do I start..
My 99 F450, did this at 225K miles.
The trans was rebuilt at 191K miles, I have the water pump, power steering pump, and lines. I bought it at 165K and have driven it for almost 3 years. Even when it had a broken valve this engine still had no blowby, it does need injectors as it won't hold over 2700ICP at WOT.
I am slowly pulling the motor, I have to wait till tax returns to have the money to rebuild it. (Time and money, I don't have much of either right now.)
I have to figure the higher rpms that the engine turns at highway speeds caused it to fail, the retainer came apart, letting the valve have some play and it broke the valve at the top and bottom of the valve stem, it doesn't look like it really damaged the head, and broken piece of valve missed the injector and the glow plug, and barely put a nick in the cylinder wall, I think a hone should take care of it. Once it is pulled I will have the bore measured, and make a decision of how to proceed.
On the 2000 X I have never been under the valve covers, I have replaced the up pipes, intake boots, alternator, and a power steering line. It has had the trans replaced once by a PO at some time, it was bought a year ago at 171K miles and has 183K now. Best purchase I have ever made. I can tell that it will need injectors in the next 20K miles though as it won't hold ICP at WOT either.
Old Feb 6, 2014 | 04:42 PM
Pikachu's Avatar
Pikachu
Up until 217k, nothing major at all. Had to make a drive to CT from TX, and had a fuel starvation problem pretty much all the way to CT, and ended up killing several injectors. Ran a compression test, and one cylinder was a little low. I made the decision to swap a late '99, 89,000 mile engine into the truck instead of replacing all the injectors and re-ringing the one cylinder.
I got a good price on the engine, so it made sense to do it that way. Well, as long as it runs when I finally get it in the engine bay, that is
Old Feb 6, 2014 | 04:52 PM
Nsaan's Avatar
Nsaan
How much did you give for the complete motor? I have seen a few on Craigslist out here and wondering what the going cost should be.
Old Feb 6, 2014 | 07:06 PM
bdpotts's Avatar
bdpotts
331,000 with nothing major removed and replaced. that being said, she could use some TLC these days. in the market for a place to work on it...
damn i love this truck!
Old Feb 6, 2014 | 07:51 PM
Franko72's Avatar
Franko72
Molon Labe
299,000 and nothing real major with the engine.
Turbo @ 230k
1st Trans @ 241k. 2nd @ 241,100. 3rd @ 241,103. 4th @ 261k
Upgraded the Injectors @ 281k
Old Feb 6, 2014 | 09:52 PM
Pikachu's Avatar
Pikachu
$1850 with turbocharger, accessory brackets, alternator, a/c compressor, p/s pump and clutch/pressure plate/flywheel that had been installed shortly before the interior of the cab went up in flames.
Old Feb 6, 2014 | 09:58 PM
87 F-150 I6's Avatar
87 F-150 I6
158,287miles, nothing major to report. Replaced glow plugs, GPR, Alts (twice), 3 front hub assemblies, Official Ford 50 cent mod, batteries and that’s it for big stuff. Everything else is regular maintenance type stuff.
Old Feb 6, 2014 | 11:08 PM
Nsaan's Avatar
Nsaan
Oh wow, your lucky, everyone out here thinks that their 300k plus worn out motor is worth 3grand. I would love to find a low mile motor like that for my truck, and then later when I had the money build this one.
Last edited by Nsaan; Feb 6, 2014 at 11:09 PM. Reason: fat fingers on a touchpad....
Old Feb 7, 2014 | 01:22 AM
Swingshiftworker's Avatar
Swingshiftworker
213k on my speedo. No major repairs since I've owned it, but I've only driven it for 10k miles. It's 1 of 4 vehicles that I own and only use it for short trips and local hauling.
The only serious problem that I've had was a faulty DP piggyback which left me stranded w/fuel problems. over 100 miles from home w/a 4000 lb Lance camper in the bed. Fortunately, I had a AAA Premier membership and got a free flatbed tow back home. Had to deflate the tires and air bags in order to make it under overhanging wires and overpasses. Took it to a ind diesel shop the next day and they almost immediately identified the problem as the DP tuner. Removed it and it ran fine. Just got a SuperChips tuner to replace the DP tuner and it has the power back again.
Old Feb 7, 2014 | 07:38 AM
timmyboy76's Avatar
timmyboy76
190k here..L99. Bought with 95k. Turbo replaced at 110k..(installed w.w. with impact and didnt 'seat" the impellor correctly). Only the usual replacement items that, like been mentioned, didnt need to be...im just ****....waterpump, powersteering pump and lpop.
Old Feb 7, 2014 | 11:04 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Donn,
Did you see this truck at the Saturday auction? Only 47k miles...
Will your body swap over to this unit?
https://sierra.proxibid.com/asp/LotD...Utility-Truck#
Old Feb 7, 2014 | 11:42 AM
  #28
Nsaan's Avatar
Nsaan
Originally Posted by Shake-N-Bake
Donn,
One that is a V 10, and 2 my insurance won't even touch a 550, since it is a personal vehicle. Thanks though.
Old Feb 8, 2014 | 09:08 AM
  #29
F250_'s Avatar
F250_
Turbo @ 230k
I hope you've found an alternative trans rebuilder.
Old Feb 8, 2014 | 10:52 AM
  #30
Franko72's Avatar
Franko72
Molon Labe
Yes I have, BTS!
