Front End Rebuild
Old Feb 5, 2014 | 06:37 PM
merc82's Avatar
merc82
Front End Rebuild
Going on about 95000 on my truck and it's about time to rebuild my stock front suspension. I was curious of what people are going with, are there any good suppliers that sell a total kit, what has held up etc. Been leaning towards Moog but how is true XRF stuff holding up?
Old Feb 5, 2014 | 07:28 PM
Snuggyworm's Avatar
Snuggyworm
What year is it? If u do Facebook, find me. I maintain a more explicit and detailed photo album on there. Let me know and I'll give u details on how to add me.
Dom
Sent from my iPhone using IB AutoGroup
Old Feb 5, 2014 | 08:26 PM
CPB1's Avatar
CPB1
What are you planning on doing, and what year truck?
I replaced all ball joints over the summer with Moog. I can't say much about how long they will last. All I can say is I don't have any loose ball joints now.
Old Feb 7, 2014 | 05:34 PM
merc82's Avatar
merc82
Sorry late getting back you guys.. it's and 06 4×4 LBCC. Looking to do ball joints, all the steering stuff and maybe even wheel bearings. Nothing special about the truck besides a leveling kit, other than that the suspension is stock and original.
Old Feb 7, 2014 | 08:53 PM
Snuggyworm's Avatar
Snuggyworm
I still maintain a thread. U can search for it. "Updates from the worm and maybe some pics".
Or if u do Facebook, send me a friend request. Once we're connected, u can go thru my tech album. I document everything explicitly. And u can see for urself if u want to still do it or not.
Dom
Old Feb 7, 2014 | 09:28 PM
CPB1's Avatar
CPB1
Unfortunately there is no kit with all the parts needed for ball joint replacement. It would be nice if there was.
I bought most of my parts and tools from Amazon.
OTC 7249 Ball Joint, U-Joint and Brake Anchor Pin Service Kit : Amazon.com : Automotive OTC 7249 Ball Joint, U-Joint and Brake Anchor Pin Service Kit : Amazon.com : Automotive
Astro Pneumatic 7868 Master Ball Joint Adapter Set - Amazon.com Astro Pneumatic 7868 Master Ball Joint Adapter Set - Amazon.com
OTC 6697 Wheel Knuckle Vacuum Oil Seal Installer for Ford 2006 To Current F-250/350 : Amazon.com : Automotive OTC 6697 Wheel Knuckle Vacuum Oil Seal Installer for Ford 2006 To Current F-250/350 : Amazon.com : Automotive
I can't stress enough how important the snap ring pliers are. I had a tough time finding them online so I had to borrow them.
Old Feb 7, 2014 | 09:49 PM
CPB1's Avatar
CPB1
The wheel bearing is contained in a hub/bearing unit. I had 155k when I did the ball joints and the hub/bearings were fine.
Along with the ball joints you should also consider replacing the hub/bearing O-ring, the hub gasket, and the axle dust seal.
This is the updated axle dust seal.
Motorcraft BRS-170 Wheel Seal : Amazon.com : Automotive Motorcraft BRS-170 Wheel Seal : Amazon.com : Automotive
I reused the knuckle seal. I did not think I damaged it while removing. I do not have the auto 4x4 so I don't need to be vacuum seal tight. You may need to replace yours.
Fandini
Aug 16, 2015 08:11 PM
dmartinez21
Dec 4, 2014 10:25 AM
sand_fiend
Mar 8, 2014 06:17 PM
jaybird
Oct 23, 2008 01:03 AM
welbyv
1978 - 1996 Big Bronco
Nov 22, 2004 03:22 PM
