96 460 refresh
Old Feb 27, 2014 | 12:51 PM
cbakker's Avatar
cbakker
Originally Posted by whalebus2112
If I go with a towing cam do I still need to bump up my timing from stock to 11-12 or leave it stock?
Not really. Advancing it by a degree or two will help performance but won't be necessary just for a cam swap.
As I said before, you need to be very careful when choosing your cam due to your SD system. I have read that comp cams #34-231-4 is a good choice to still operate within SD.
Old Mar 31, 2014 | 05:07 PM
whalebus2112's Avatar
whalebus2112
Well after a month and $1700 later I finally got my motor back from the machine shop today. 2 walls were a little oval so it got bored out and the head got new seats and seals and lapped in and springs were checked and a new stock cam.
The bottom got bored ,crank turned and new pistons. I will get started on building the block tomorrow and get some pics up.
Old Mar 31, 2014 | 05:17 PM
cbakker's Avatar
cbakker
Sounds like you went about it the right way. Be sure to use plenty of lubrication during assembly. It is best to use assembly oil, but if you are using regular oil, use a lot.
Good luck!
MAULMAUL
May 17, 2020 05:01 PM
Hardlanding
Jul 9, 2015 05:24 PM
neil 95 e350
Sep 19, 2008 12:29 PM
wintremute
Nov 17, 2007 09:21 AM
rakent
May 16, 2004 12:17 AM
