1977 F-150 help, won't start - I think spark???
Hello, I have a 1977 F-150 Custom, auto, 4x4, 351M with more miles on it then the speedo can remember. It has less then 5000 miles on rebuilt engine, and tranny. However it sat for 8 years, and I just put a new carb on it and she would run good. Also new in the last 100 miles - spark plugs, dist cap, rotor, air filter, fuel filter, fuel pump, fuzzy dice.
One day it was a blizzard outside and -20 temps. She started with a little cranking, then I busted through some snow drifts to get out of my driveway. (a lot of snow in the engine bay). About 100 feet after my driveway she just died, and will crank and turn over but won't start. That was 2 weeks ago.
I cleared most of the snow out, still a good amount in there. I took a heat gun to my carb to melt anything that might be frozen in there. My gas is almost new, and has SeaFoam in it. I did a squirt of Either down the carb but she won't even try to start.
So, with temps still around 0 outside and no helper, what should I check on next to get it going? Should I pull the coil wire and see if I get spark there? I have done some searches and looks like Ignition Module would be a place to start?
Thanks in advance
Thanks in advance
Yes, you should check for spark. If you do not have spark, there are several steps to check first before suspecting the ignition module.
The safest and easiest way is to use a spark tester. In the absence of a spark tester, you can unplug the center wire from the distributor cap, insert a flat-blade screwdriver up into the wire boot, and hold the screwdriver shaft close to the block. Check for a solid blue spark while a friend cranks the engine. Stay clear of the fan and don't lean on any sheetmetal.
InspectorCallahan
19
01-18-2014 05:34 PM
lonerangermotors
12-13-2012 03:50 PM
