6.0 to 12v Cummins swap
#61
Ok, I ran over to it over lunch and re-indexed the pump lever. Started right up! Drove it around the block with no hood and parked it because I had to get back to work.
Video from right after it fired.
VIDEO0022_zps9d4a806d.mp4 Video by kert0307 | Photobucket
#63
More like need more time... still have a few adjustments to make with stuff in the pump because it was a little doggy and had more turbo lag than I would like. But there's still quite a bit of turning up I can do with the pump.
-After I run it a little I'm going to adjust the valve lash.
-The engine oil and coolant both have system flush products in them as well that will need drained and flushed after I drive it a little more also. The coolant is looking pretty dirty already so I'm glad I'm getting some of it out of there.
-I also still have some driving and data logging to do to send to the tuner to do the trans as well.
-Nothing on the AC is hooked up yet just the compressor for the belt.
-Still have to hook up a cruise control servo
-Still need fan and shroud
#65
#68
#69
Received 5,160 Likes
on
#70
First round of trans tuning showed up in my email yesterday evening. Definitely an improvment of the 6.0 strategy, but there's still a little work to do. I was able to make a WOT pass up a hill by my house and it maxed out at 26psi and 930ish on the egt. With that info I'm going to turn the pump u a little more
#71
For those curious about money....
So far total parts cost is right around 8k...Keep in mind this includes some stuff like a new AC condenser, new all aluminum intercooler, in other words I didn't exactly go cheap on this, I wanted to try and make sure that I don't have to replace any weak links or marginal parts.
I've sold about $1500 of 6.0 parts and have about another $1500 left in parts to sell. So total cost is going to be right around 5k. When it's all done I'll post up the spreadsheet I've been keeping.
#74
Sent some emails back and forth with DCS. Seems like part of my issue might be that I broke the nipple off my MAP sensor so I haven't gotten it hooked up yet. I do have a new one ordered. Also my tach has a little bit of a flutter to it above 2k so I'm going to recheck my tach ring spacing and alignment when I have some free time and see how it affects the trans tuning. They said both of those play a part in what their tuning looks for in trans shifting.
#75
