Sponsored by: Real Truck
composite rust repair panels
Old Feb 4, 2014 | 09:04 AM
bbender85's Avatar
bbender85
has anyone seen/heard of these, or better yet have any experience with them?
Bed Side Wheel Arch Repair Panels "Composite" Ford F250 350 | eBay
thoughts?
power washed a paint chip off the other day exposing what i knew has been lurking.
Old Feb 4, 2014 | 09:13 AM
05F250DSL's Avatar
05F250DSL
To me looks like more hassle. If you drill out the inner wheel panel you an get to the backside of the bedside and grind/ media blast the foam and rust out. Epoxy coat it and seal it from moisture. Or weld in replacements and clean seal the backside before installing a new inner wheel house. Most panel bond requires bare metal for the best bond. Without removing the inner wheel house how do you know all your bare metal is covered and the seam is sealed??
Old Feb 4, 2014 | 09:18 AM
bbender85's Avatar
bbender85
i don't know whats involved in removing the inner well but i think you would want/have to anyways? maybe not.
Old Feb 4, 2014 | 07:53 PM
05F250DSL's Avatar
05F250DSL
Spot weld bit and 25 min or so. I have to do mine as well. I will wait il spring/ summer when the shop slows down. Remove and replace the inners and like stated blast and epoxy inside and out. Then fill any pits left and repaint. Mine are just bubbling. I've only owned the truck since Late sept.
guessrow
2004 - 2008 F150
Mar 23, 2012 10:05 AM
hacking_in2002
Paint & Bodywork
Jun 1, 2006 05:26 PM
frederic
Apr 15, 2005 09:53 PM
Ben88f150
Paint & Bodywork
Apr 5, 2004 12:57 PM
VIBR8R
Paint & Bodywork
Jul 11, 2003 10:02 PM
