Message Center buttons not working
Old Feb 3, 2014 | 07:15 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
A couple of weeks ago, had a weird thing happen.
When turning left at slow speed there was a click sound that came from the upper part of the steering column (similar to the sound you got with the indicators on in the old super duties when turning and it would go over the clockspring). It hasn't repeated the noise since.
Anyways, a week or so after this, I happened to try to use the buttons for my message center to reset my odo, which I rarely use. Didn't work. In fact all of the 5 buttons associated with the message center on the left side of my steering wheel are not working, but the cruise control buttons are. The buttons on the right side of the steering wheel are also working fine.
I am not sure if the noise in the steering column is related (but it has me suspicious...), or just coincidental, but wondered on peoples thoughts to diagnose.
I pulled off the cover over the steering column, all the wires in and out of the clockspring look fine, I haven't pulled the switch yet (need to look at the service manual to make sure I don't break it as I do it), but wanted to see if anyone else had experienced this, and if so, what was the diagnosis.
Old Feb 4, 2014 | 08:34 AM
darren32's Avatar
darren32
About the only thing between the buttons and the IPC is the clockspring .... I would check for continuity across the clockspring first.
I am sure you are aware, all 5 buttons are a single circuit with varying resistance.
File Type: pdf
Old Feb 4, 2014 | 10:31 AM
BigF350's Avatar
BigF350
FTE Emeritus
Thanks, I might do that. I guessed it was a single circuit, but didn't have the wiring diagram to reference (thank you for posting it, I really appreciate it).
The wiring diagram doesn't reference the CC going through the clockspring, and at least not on the same loom, so that makes me more suspicious that its the clockspring.
I'll see if I can test it with my friend this weekend who has all the electrical testing equipment. If it can't be repaired with a hammer, I am pretty useless
Old Feb 4, 2014 | 10:52 AM
darren32's Avatar
darren32
Actually CC deos go to the same connectors on the clockspring C218A and B. So IDK if only some points in the clockspring can fail and not others .
But CC goes to SCCM and 5 button goes to IPC.
I was just looking at this the other day because I have the opposite problem, 5 button works but CC does not.
File Type: pdf
Old Feb 4, 2014 | 01:28 PM
BigF350's Avatar
BigF350
FTE Emeritus
Thanks again, that 2nd wiring diagram is really helpful.
I think for both of us, it either has to be the clock-spring or the switch
TheBlueMule
1978 - 1996 Big Bronco
Jun 2, 2010 03:48 AM
barrycm
Nov 25, 2009 01:59 PM
cowmilker08
Feb 11, 2009 03:02 PM
XLT_explorer
Electrical Systems/Wiring
Jul 28, 2008 09:28 AM
far200
Jun 2, 2004 11:21 PM
