So i have a 74 ford f100 with a 76 460 in it, and I was wondering what I could do to wake her up a little bit. She is stock as far as I know, with some tune up work done. I want to spend around 500-600$ to do some easier engine work. I don't want to have to tear the engine apart, just do some things to get some HP and torque gains. What can I do to wake up this beast???
Quick and easy is the air filter, then intake and carb. A couple of hrs and your are done. Open up the exhaust less restrictive mufflers, might as well go with headers since you are right there.
The headers will required some exhaust re-work and that can be more $$ in the end, but its only $.
If you crack it open for a cam install, might as well do a straight up timing set and a new water pump.
Only thing better than NOS, is a GF that owns her own liquor store and 79 Ford truck. lol
