302 EFI Conversion
Old Jun 28, 2003 | 07:39 PM
malonejy's Avatar
malonejy
Question 302 EFI Conversion
I have the original 302 in my 73 Bronco that is about to be rebuilt. Saw this on ebay and wondered what you guys thought.
ebay
Is this everything I need to do the conversion? What about the price?
Old Jun 29, 2003 | 06:29 PM
LxMan1's Avatar
LxMan1
302 EFI Conversion
You could probably by a junk car cheaper and strip everything off of it. It would be a little more work, but it would save you some money.
Old Jun 29, 2003 | 11:30 PM
Ford_Six's Avatar
Ford_Six
302 EFI Conversion
You will also need the valve cover shown with the tall oil fill- unless you like flexible funnels.
Old Jun 29, 2003 | 11:39 PM
Ace_Wrench_47's Avatar
Ace_Wrench_47
302 EFI Conversion
I agree that buying a junk car and stripping everything off it would be cheaper.....but how much of that stuff you stripped would be Junk!? And how much of an expert are you at stripping everything needed for the fuel injection setup.....computer, sensors, etc?
The Ebay setup sure looks cool. But what is it you really want? The ad says "no hesitation and great fuel economy". Take it from an old wrench, good old fashioned carburetors don't hesitate when they are in good repair and operating correctly. And fuel economy?? What exactly does the Ebay ad mean when it talks about fuel economy? Are they telling you that you'll have good response and performance and good economy to boot? Isn't there a little part of you that says that's just a big fat lie? There should be.
Up until the 80's, all cars had carburetors. Most of the time they worked great. Good mechanics could fix em when they went south. But good mechanics were hard to find. So carburetors sometimes get a bad rap.
The fuel injection setup looks cool. But for $1000 I could probably set you up with a blower. Unless you have a good reason for wanting fuel injection - spend your "looks cool" money on wheels and tires, or a new camshaft and headers with dual exhaust. Having fuel injection instead of a carb isn't gonna make you feel too cool 6 months or a year later. Especially when a sensor or the computer goes out and you don't know how to begin diagnosing it. Then take it to the dealer and realize they can't diagnose a non-factory car either.
Old Jun 30, 2003 | 07:36 PM
LxMan1's Avatar
LxMan1
302 EFI Conversion
The fuel injection is more efficient and is USUALLY a smoother running set up. My 88 5.0 Mustang runs 7.90's in the 1/8th mile, gets 18mpg and has cold a/c. Try this on an 83-85 with a holley carb. It ain't gonna happen.
If you have the knowledge of what it takes to make the fuel injection work, and can do your own fabrication to things that don't quite fit, then I would convert it over.
Just a quick note, you would want a EFI set-up off of a big car( LTD, Town Car, ETC) You do not want one off of a Mustang or a LSC Mark VII Lincoln. These use the 351 firing order and are sequential EFI. The others use the standard 302 firing order and are batch fired. Plus you would either have to change the distributor or find a different gear because the HO motors have roller cams and use a different gear. If you use it in a non-HO motor, it will wear out rather quickly. Oh, yeah, you can also use a T-Bird or Cougar 5.0, they are also non-roller.
Jimmy
axelgawn
Jun 8, 2016 02:33 PM
SVTDriver97
Feb 2, 2015 12:52 PM
Rusty_S
18
Jul 14, 2014 08:08 PM
lakewood
May 24, 2012 02:13 PM
Sickler1
Dec 27, 2011 08:09 AM
