Rigid Dually D2's
Old Jan 31, 2014 | 10:36 PM
crazyduck's Avatar
crazyduck
Rigid Dually D2's
I want to install some Dually D2's where my fog lights are and will use the Driving model instead of spot or flood. Can i run these at night with oncoming traffic or will they be to bright? I like running my fog lights on low beam so don't want to lose that option. I've got the 20" light bar wired into my bright lights so would like to have a little more light on low beam but don't want to make oncoming motorists mad by blinding them. I found a mounting bracket online and i can angle them in many different directions so wasn't for sure if i could point them down some and get away with it.
Old Jan 31, 2014 | 10:59 PM
Wizness's Avatar
Wizness
I just installed these on the front of my truck. There is NO WAY you can run these while driving. They will blind anyone. Seriously they are ridiculous bright for other drivers. They are awesome though. For instance, I just use my upfitter switch and use them whenever I want. Only thing that sucks is not being able to use them all the time. Makes a big difference.
Here's my set up.
Old Feb 1, 2014 | 10:54 AM
2ndStroke's Avatar
2ndStroke
No way could you leave them on. I have 4 mounted and 2 pointed right for the ditch. These little things light up the tops of the trees along the highway, light output is crazy.
Old Feb 1, 2014 | 07:11 PM
crazyduck's Avatar
crazyduck
I kind of figured they would be to bright to run all the time. Since i have the 20" bar, I guess i'll leave my fogs stock.
Thank you for the input….
Old Feb 2, 2014 | 06:27 PM
rtazz17's Avatar
rtazz17
Here's my set up.
Did you use the stock brackets that came with the lights or did you have to buy or make bracket separately to install there?Look good.
Old Feb 2, 2014 | 07:49 PM
Wizness's Avatar
Wizness
I used a single piece of aluminum angle iron. There are already pre drilled holes on each side you can see if you look in the bumper so that's where I attached it too. Not the best pics but it may give you an idea.
Old Feb 3, 2014 | 09:46 AM
rtazz17's Avatar
rtazz17
Thanks
10 characters
Old Feb 3, 2014 | 10:12 AM
SavageNFS's Avatar
SavageNFS
Nice install Wizness...I rep you, but it says I have to wait a bit
Old Feb 3, 2014 | 11:02 AM
Leonandlisa's Avatar
Leonandlisa
For those of you that have installed these, what color did you go with? I noticed they have different color LEDs. Also what would you suggest for back dirt road use (Spot, Flood, or Driving)?
I went to their website and I didn't find much additional information, so any suggestions would be appreciated.
Old Feb 3, 2014 | 11:05 AM
Wizness's Avatar
Wizness
I personally like the driving pattern the best but it's all preference. It gives a good balance of distance and spread. So far I haven't had a problem with any type of road service and mine are white. You can always buy different color lens covers I believe if you want to try something different.
Old Feb 3, 2014 | 12:48 PM
Leonandlisa
Thanks WIZ, appreciate it.
Old Feb 3, 2014 | 07:53 PM
saratoga2011's Avatar
saratoga2011
I've got the D2 Driving beams in place of my factory fogs. They're awesome but wayyyy too bright to use with oncoming traffic. The beam spread is tall like a giant oval that you can see in the trees at night.
Old Feb 3, 2014 | 09:27 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Good Job Mr. Wiz !! I rep'd him for Savage.
Old Feb 4, 2014 | 06:10 AM
SavageNFS's Avatar
SavageNFS
Thanks Tim!
Old Feb 12, 2014 | 06:00 PM
rtazz17's Avatar
rtazz17
Wizzness,I received my dually d2s and rear floods today.I dont need to use the relays they came with if im wiring to upfitter switches correct?Just positive and negative wires.. Upfitters have there own relays.Just want to be sure and not f&$& it up.Thanks
