Fuel Pump ??
Old Jan 31, 2014 | 03:19 PM
LjH's Avatar
LjH
Fuel Pump ??
1994 F150 XLT 5.0 Automatic extended cab 4x4..
I have owned this truck for 8 years. It currently has 179xxx and runs great. A few months ago I replaced the ABS sensor and the rear fuel pump. When I bought the truck I replaced the front fuel pump with a new Ford pump. Now when running on the front tank it backfires and looses power under a load. I also occasionally get a check engine light. It’s fine on level ground. When it starts backfiring I can switch tanks and it immediately picks up and pulls strong and within a mile the light goes off. Everything points to a bad front fuel pump. However when I check the fuel pressure it is the same on either tank. I am amazed that the Ford pump ($265.00 in 2006) only lasted 8 years considering I drive the truck very seldom. Does anyone have any ideas other that replacing the front fuel pump again?
Old Jan 31, 2014 | 04:56 PM
Conanski's Avatar
Conanski
You need to rule out a fuel problem and to do that setup a fuel pressure gauge so you can see it inside the cab while driving to see if pressure drops when the poor performance occurs. Also pull the codes, doesn't matter if the light is currently on or not codes are stored for persistent problems.
Old Jan 31, 2014 | 05:08 PM
LjH's Avatar
LjH
Thanks for your prompt response. I look into that as soon as I can..
subs1000w
Large Truck
Mar 13, 2019 12:17 PM
RICHXL7
Dec 26, 2017 09:25 AM
870
Jul 19, 2008 08:42 AM
krzyk26
Mar 29, 2005 05:49 PM
Tom's Truck
1997 - 2003 F150
Dec 21, 2003 11:46 PM
