6oh issue
Old Jan 31, 2014 | 07:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
6oh issue
I received this last night ...long long time friend of mine
Tim some background info for the post.
Question: garage kept 6.0 43k miles was parked outside overnight in 10 deg F weather started dripping coolant later the next day. Truck was parked nose down on an incline hill when it was notice to have a small drip off front of block. After investigating a the coolant was on passenger side of intake. What could be leaking under or the near the turbo? Intake was removed by dealer at 12K miles for warranted work.
I should be at my desk for sure after 8:30.
Old Jan 31, 2014 | 07:36 AM
npccpartsman's Avatar
npccpartsman
Most likely it's the small oil cooler to EGR cooler hose (orange or blue in color) leaking. Typically happens when cold. Very common.
Small orange hose in this picture: http://www.backglass.org/duncan/ps60...l/ps60_074.jpg
Old Jan 31, 2014 | 07:38 AM
Toreador_Diesel's Avatar
Toreador_Diesel
I'm thinking the same as well...
The easiest way to get to it without struggling and hurting yourself in the process is to remove the turbo. It doesn't take very long and you're not trying to squeeze your fingers into a tight area to change that hose.
Old Jan 31, 2014 | 08:39 AM
9228.bobcat's Avatar
9228.bobcat
Yup thats it. Cheap fix.
Old Jan 31, 2014 | 08:55 AM
IB Tim's Avatar
IB Tim
OK average Joe how long to do the entire job.
Just ho long to pull turbo.
Do we have a good procedure for doing this.
Old Jan 31, 2014 | 09:02 AM
9228.bobcat
I personally wouldnt remove the turbo. There is a write up on it in the tech folder under egr cooler hose removal and install. Average joe I would say hour or less.
Old Jan 31, 2014 | 09:12 AM
npccpartsman
I would remove the CAC pipe for easy access but no need to remove the turbo.
https://www.ford-trucks.com/forums/1...l#post10609697
Old Jan 31, 2014 | 09:13 AM
Toreador_Diesel
I've had the turbo out on my buddy's '07 F350 and found that hose was really easy to get to, that's why I suggested it.
Old Jan 31, 2014 | 09:17 AM
9228.bobcat
Oh agree its easier. But not worth taking it out unless you have to pull it for some other reason.
Old Jan 31, 2014 | 09:37 AM
MMBI's Avatar
MMBI
Thanks All for the help! I have some work to do this weekend.
Old Jan 31, 2014 | 09:38 AM
IB Tim's Avatar
IB Tim
Guys this is my friend....welcome Chris.
Old Jan 31, 2014 | 09:43 AM
npccpartsman
Welcome to the 6.0 forum Chris. Lots of great guys here and a wealth of 6.0 knowledge. You'll be well taken care of...
Old Jan 31, 2014 | 09:55 AM
Toreador_Diesel
Welcome Chris!
Happy to have you here!
Old Jan 31, 2014 | 09:59 AM
9228.bobcat
Welcome Chris. Any questions just ask.
Old Feb 1, 2014 | 08:26 AM
IB Tim's Avatar
IB Tim
He will have more when he remembers his password
