1978 - 1996 Big Bronco
no idea!! please help!!
Old Jan 31, 2014 | 01:18 AM
Titanic15's Avatar
Titanic15
Just got hom from work drove the bronco. Going down the road its 55 bronco wouldn't let me go past 45mph. Everytime I get on the gas it acts like its not breathing at at all. It will syart jumping. Any ideas what it could be?
Old Jan 31, 2014 | 04:26 AM
gatorfor88's Avatar
gatorfor88
What else does it do? Any strange sounds? Are the cats glowing red? lil mo info
Old Jan 31, 2014 | 08:43 AM
Titanic15's Avatar
Titanic15
It would just bog down. If I put the gas to the floor you would hear this popping sound from underneath...almost like back fire. I've been told transmission, coil pack, or fuel injecters
Old Jan 31, 2014 | 09:59 AM
Kemicalburns's Avatar
Kemicalburns
pull codes, and also check fuel pressure at the rail with a fuel pressure gauge. check with key on and with engine running then report back.
may also be a clogged catalytic converter.
also just curious have you done any maintenance to the bronco recently?
Old Jan 31, 2014 | 11:40 AM
Titanic15's Avatar
Titanic15
Just a oil change new wheel bearing and new smog pump
Old Jan 31, 2014 | 04:14 PM
peganit2's Avatar
peganit2
That is exactly what nine did a few weeks ago.
It was the fuel system, the pump or the filter.
Change your fuel filter first!! It takes 10 minutes with the right tool and costs $20.00 or so.
I changed the pump AND the filter at the same time, I may have been able to just do the filter. (internet analysis!)
Old Jan 31, 2014 | 10:44 PM
greystreak92's Avatar
greystreak92
I'll second the idea that it is likely to be a clogged catalytic converter.
Old Feb 5, 2014 | 01:27 AM
Titanic15's Avatar
Titanic15
Alright so I replaced the fuel filter! And did a pressure check on the fuel rail was fine. Have no idea wtf is going on. When I pulled the old filter out it just leaked out the most dirty fuel I seen in my life time! But new filter is in and new fresh gas is in and still doing the same crap!!!!! I'm now thinking clogged cat or massive vaccum leak...
Old Feb 5, 2014 | 03:22 PM
Kemicalburns
unhook your y pipe from the manifolds and take it for a quick drive. it will be pretty loud for sure so dont go to far. This wont hurt anything and you will find out fast if the issue was the cat or not.
and when you say the fuel pressure was fine what was it exactly? and did you perform both the key on and engine running tests?
Old Feb 5, 2014 | 04:56 PM
peganit2's Avatar
peganit2
It was the same with my filter. Rusty brown and trickling out.
No loss in the change.
Jessie Castonguay
Bronco II
May 23, 2013 08:46 PM
dencrawford
Bronco II
May 1, 2012 06:01 PM
jpuck88
May 14, 2010 11:32 PM
dino360
19
Mar 23, 2005 11:01 PM
