turbo
Old Jan 30, 2014 | 07:06 PM
ken1960's Avatar
ken1960
turbo
my truck under throttle sounds like a jake brake noise that kicks in an out comming from turbo does it supose to do that
Old Jan 30, 2014 | 07:08 PM
2ndStroke's Avatar
2ndStroke
I don't think so...
Is this in tow mode?
Old Jan 30, 2014 | 07:14 PM
kper05's Avatar
kper05
Nothing should be sounding like that. What year? Is it stock?
Old Jan 30, 2014 | 07:21 PM
2ndStroke's Avatar
2ndStroke
I know my straight piped 6.7 can kinda sounds that way in tow/haul and I'm slowing down, more with the downshifting though...I forget how mine sounded stock now.
Think you got issues..
2ndStroke's Avatar
2ndStroke
Old Jan 30, 2014 | 08:15 PM
ken1960's Avatar
ken1960
it is a 2011,and i dont have it in tow /haul, the engine light been on for awhile with a p401 code had ford put new egr on but poped back on i guess the egr filter dirty. i am in okeechbee fl. on vacation , going to go to diffenrt dealer than here to get fixed . and it is stock with 43000 on it 16mpg.thinking about put h&s race tuner on it , that will make light go off .and thought about trading it in on a 2014. dont no if they are any better than the 2011 , maybe few bugs were worked out .
Old Jan 30, 2014 | 08:22 PM
kper05's Avatar
kper05
There isn't sound back there so technically, you've not forgotten anything.
P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient Detected
Old Jan 30, 2014 | 08:26 PM
2ndStroke's Avatar
2ndStroke
H&s will make the light go out, but I would make sure the turbo is ok first.
Old Jan 30, 2014 | 08:27 PM
2ndStroke's Avatar
2ndStroke
The nothing is all coming back to me, wait, that doesn't make sense
Old Jul 3, 2017 | 08:24 AM
sonar_91's Avatar
sonar_91
P401
I am having the same issue with my 2013.....Check engine light comes on after about 5-10 minutes of driving at highway speed...always same code P401.....drivability NOT affected......check engine light does not come on during in town conditions...any ideas on what I can do before spending money on a diagnostic and/or repair?
Old Jul 3, 2017 | 08:48 AM
djousma's Avatar
djousma
Most likely plugged EGR cooler. you wont notice the reduction in power until you are towing something heavy. Get it in, should be under engine/emissions warranty.
Old Jul 3, 2017 | 06:34 PM
sonar_91's Avatar
sonar_91
Unfortunately, not the factory warranty as truck was purchased certified used and extended warranty does not cover emissions. This may be jumping to conclusions though, won't know what is causing the problem until the diagnostic is run and that won't be until next week and that is 125 bones. If it is the EGR cooler, that is a about 700 additional monies spent. BTW- please define what "heavy" is as far as loads are concerned...hate to have a 16.5' Crestliner cause limp mode......
joe blow
Mar 21, 2025 09:40 PM
hawkrdr
6.7L Power Stroke Diesel
Aug 29, 2019 07:10 AM
outdoormaniac
Mar 2, 2014 06:23 AM
w_huisman
Feb 12, 2009 01:24 PM
