Sponsored by: Real Truck
transmission help please
Old Jan 30, 2014 | 04:59 PM
kylbbb22's Avatar
kylbbb22
I have a 00 super duty 4x4 I was out playing in the desert and was just about to go up a sand hill when everything felt like it shifted into neutral I had the hubs locked but it was only in 2 wheel drive I have no gears what so ever the pump is sucking fluid down and I changed the filter out still nothing when running I can pull it all the way down into 1st and all the way back to park makes no noise and can put in 4 low while running and in gear
Old Jan 30, 2014 | 05:09 PM
jesse5's Avatar
jesse5
Welcome to FTE!
Sounds like a tranny failure. Ford reman unless there is a professional remanufacturer in your area that does the upgrades.
Old Jan 30, 2014 | 05:45 PM
kylbbb22's Avatar
kylbbb22
I was told possibly the converter or input shaft could be bad
Old Jan 30, 2014 | 06:24 PM
redford's Avatar
redford
FTE Leadership Emeritus
You can speculate all you want, but at this point, a tear down and inspection is probably in order.
Old Jan 31, 2014 | 03:55 PM
kylbbb22's Avatar
kylbbb22
Yeah ended up being the transmission I pulled it last night
80ford100
13
May 17, 2015 06:47 PM
MexicanScaper987
Nov 16, 2012 08:24 PM
sudsmcduff
Jul 22, 2012 11:09 AM
87f350banksequiped
Jan 17, 2010 07:09 PM
Fmodster303
Apr 10, 2006 07:51 AM
