ficm
Old Jan 28, 2014 | 11:51 AM
skinny29286's Avatar
skinny29286
ficm
My FICM i no is not ever suppose to drop below 45 and warm runs at 47 to 48. But like rught niw it is 10degrees out side and it started at 35 but when warmed up is at 48 is this normal or is there a mod i need to do
In the summer it starts at 48 no prob.
Old Jan 28, 2014 | 11:54 AM
clevelandtundra's Avatar
clevelandtundra
It's on its way out. Start putting cash aside and think about your options (FICMrepair.com etc). Mine would go down to 37 V while cranking and then climb back up - even made it through an entire winter without an issue. But ultimately I replaced it.
Old Jan 28, 2014 | 11:57 AM
npccpartsman's Avatar
npccpartsman
Time to send it to Ed at FICM Repair.com - Your Source for FICM Repair
Old Jan 28, 2014 | 11:59 AM
King-bRanch's Avatar
King-bRanch
No.....It's NOT normal the FICM is dying
It may last 3 months or it may die tomorrow theres no sure fire way to tell, when mine did that i sent it to Ed @ FICMrepair.com
That was about 2.5 years ago & i still have a constant 48.5-49 volts no matter the Temp
King-bRanch
Old Jan 28, 2014 | 12:01 PM
King-bRanch
^^^^^^ What happened there
Double posted somehow but with different emoticons
Old Jan 28, 2014 | 01:29 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I think FTE is all messed up... I'm getting email updates today from posts 2 days ago.
Josh
Old Jan 28, 2014 | 03:02 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I'm getting emails about PM's that were supposedly from yesterday but are 3 days old .
Old Jan 28, 2014 | 03:08 PM
acf6's Avatar
acf6
Josh
Im glad im not the only one thats happening too...
Old Jan 28, 2014 | 05:55 PM
05F250DSL's Avatar
05F250DSL
I'm with the rest it's going out mine never drops and stay48.5-49v under all conditions. I am not sure what you would get if you had low batteries. I just tested this Sunday when I was left on the side of the road. The wife had been driving the truck said I had just under a 1/4 tank so I figured its cold out I will go fuel up. Didn't make it started going over the numbers all looked good had a buddy help me get to said fuel and she runs like a champ apparently my fuel gauge does read right under a 1/4 tank.
Old Jan 28, 2014 | 08:11 PM
skinny29286
Should i check the voltages on the batt and alternator could that cause the low voltage
Old Jan 28, 2014 | 08:12 PM
skinny29286
And what about that blue spring up grade good idea or no
Old Jan 28, 2014 | 08:27 PM
Bullitt390's Avatar
Bullitt390
Blue Spring is highly recommended.
As for alternator, make sure it is charging 13.5+ volts at the battery after the glowplugs shut-off from a cold start.
Josh
Old Jan 29, 2014 | 11:58 PM
skinny29286
I installed. A new batrwey other was bad will that fix the prob
Old Jan 30, 2014 | 05:43 AM
acf6's Avatar
acf6
No, they need to be replaced in pairs
