Correct Wheel Fitment.
Old Jan 27, 2014 | 07:39 PM
ScumbagSteve's Avatar
ScumbagSteve
Question Correct Wheel Fitment.
1994 F150 5.0L 2WD XLT Long Bed Extended Cab
I've just got a quick question about a set of wheels. I was just curious to see if they would fit correctly. Truck wheels and car wheels are a little different.
http://www.summitracing.com/parts/sum-85-7885/overview/
Brand: Summit Racing Manufacturer's Part Number: SUM-85-7885
Part Type: Wheels
Product Line: Summit Racing® 85 Black 8 Series Wheels
Summit Racing Part Number: SUM-85-7885
Wheel Diameter: 17 in.
Wheel Width (in): 8.000 in.
Wheel Material: Steel
Primary Wheel Color: Black
Wheel Finish: Gloss
Manufacturers Wheel Series: Summit Racing 85 Series
Backspacing (in): 4.000 in.
Offset: -12.00mm
Wheel Construction: 2-piece
Beadlock Functional: No
Beadlock Included: No
Lug Nut Seat Style: Conical seat - 60 degree
Hub Centric: No
Center Cap Included: No
Load Rating (lbs): 2,100 lbs.
Valve Stems Included: No
Quantity: Sold individually.
Wheel Bolt Pattern: 5 x 5 1/2 in.
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old Jan 27, 2014 | 08:12 PM
Conanski's Avatar
Conanski
Yeah those will fit.
Old Jan 27, 2014 | 08:20 PM
mrrish79's Avatar
mrrish79
Your bolt pattern is 5x5.5 so yes they will fit. Not sure of the backspacing on a F150 though.
Old Jan 27, 2014 | 08:24 PM
Conanski's Avatar
Conanski
Backspacing on stock Ford wheels is 4" max.
Old Jan 27, 2014 | 08:26 PM
ScumbagSteve
What is the backspace for the original wheels? I have the 15" swirl wheels.
Old Jan 27, 2014 | 09:47 PM
Conanski's Avatar
Conanski
Stock Ford wheels were available in various widths from 6" to 8" over the years but they all have zero offset which means backspacing is 1/2 the wheel width.
Old Jan 27, 2014 | 11:57 PM
ScumbagSteve
So these wheels with a 4" backspace and a -12 offset will work?
milkweed.gardener
May 21, 2021 12:17 AM
Don_Larson
Jun 8, 2012 02:05 PM
mikedeason
May 11, 2007 12:27 AM
GeneStoner
Jan 10, 2004 11:42 PM
