Has anyone started at -20f without plugging in?
Old Jan 27, 2014 | 06:19 AM
KC8QVO's Avatar
KC8QVO
How low have you gone? I've done about -10 so far and didn't have any issue. I don't have a heater on this truck anyway, just curious. I hope the extra 10deg doesn't kill my chances. -2 here now and dropping, may be close to -20 by the end of the day. I suppose if I crank it up for lunch it may not be so bad come time to go home...
Old Jan 27, 2014 | 06:38 AM
senix's Avatar
senix
Here is a thread of a few cold starts:
https://www.ford-trucks.com/forums/1...old-start.html
I have started mine at zero so far. With the remote of course. Did not take any additional start up time.
One thing I notice is the 6.7 does not clank as much in those temps as the 6.4 did. Not sure why but it is quieter.
Old Jan 27, 2014 | 06:43 AM
KC8QVO's Avatar
KC8QVO
Ah. -30 or so unplugged... I feel better now. I don't think it will get that cold here. Thanks Scott.
Old Jan 27, 2014 | 07:18 AM
bridge's Avatar
bridge
No, my trucks never been to the dark side of the moon.
Old Jan 27, 2014 | 07:28 AM
TRENT310's Avatar
TRENT310
Yes. Multiple times.
It will give you the 30 second warm-up count down when you start nearing those temperatures.
Old Jan 27, 2014 | 07:45 AM
96sherm's Avatar
96sherm
It'll sound rough, but it'll start if your batteries are in good condition. I've had to do it in those temps and lower when staying at hotels.
Old Jan 27, 2014 | 07:59 AM
WildWildWest's Avatar
WildWildWest
Many times - no problem with these trucks. Just takes a little longer to warm up.
Old Jan 27, 2014 | 09:31 AM
U235Fishin''s Avatar
U235Fishin'
Just so long as the fuel is not gelled.
Old Jan 27, 2014 | 11:49 AM
JimPat's Avatar
JimPat
-16 for me. cranked right up. Fuel was gelling a bit as it was out in the wind all day but since I switched to DK white bottle, haven't had that issue.
Old Jan 27, 2014 | 12:40 PM
Brandon Bloomquist's Avatar
Brandon Bloomquist
-11 for me. It wasn't happy about the cold soak all night, but it went.
Old Jan 27, 2014 | 11:42 PM
boatflounder's Avatar
boatflounder
well hell now am even mader about that wasted 75 dollars, never could figureout why my truck had an engine bocke heater?!?! mght get to 28 tomorrow at which point the truck int moving anyway!
Old Jan 27, 2014 | 11:55 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Great Falls Montana......07 Dec 2012.
Minus 33*F.......Lost power in the area at 2:00am Had to start the truck at 10:00am.........NO Problem. It just started and ran at about 1100 rpms. Did the 30 second count down. I let it idle for 10 mins before driving off. Ran fine. I do like to plug in when the temps go below +10*F just to be nice to the engine. I do run 5W 40 syn Shell oil. Standadyne Diesel fuel additive....1 oz per 3 gals of fuel. No gelling problems.
Great Truck!!
Old Jan 28, 2014 | 08:57 AM
brandon4's Avatar
brandon4
North Dakota. wind chill of -68 a couple weeks ago didn't even know these trucks had a block heater. Sounded like a Model T for a bit each time I did it. it'll crank itself over 2or 3 times then fire.
Old Jan 28, 2014 | 08:58 AM
brandon4's Avatar
brandon4
I run Mobil straight Synthetic.
Old Jan 28, 2014 | 08:32 PM
Jim5x5's Avatar
Jim5x5
-19 with wind chills approaching -50 and fired right up. Was noticeably slower turning over, but fired right up.
