Thermostat Install
Old Jan 26, 2014 | 12:00 PM
Subzero68's Avatar
Subzero68
Thermostat Install
As from my other thread, some members here said my thermostat is bad based on my ScangaugeII reading. Here's the thread https://www.ford-trucks.com/forums/showthread.php?p=13999012#post13999012 . I have never done this and am trying to figure out if this is something that I could do myself or do I need to go to a shop. What all is involved to change out a thermostat on a 2003 F250 6.0? Will I need to add more coolant? What are some good brands of thermostat?
Old Jan 26, 2014 | 12:14 PM
w_huisman's Avatar
w_huisman
Get a thermostat from Ford. Too many poor thermostats available from other suppliers.
Drain a couple of gallons of coolant out of the bleeder at the bottom of the radiator. Then the thermostat comes out by loosening a hose clamp and the two housing bolts. Nothing to it. Put everything back together and poor the coolant back in.
Old Jan 26, 2014 | 12:21 PM
jswartz84's Avatar
jswartz84
Its just as easy as that.
I leave the hose attached and use it to pull the t-stat housing up for easier access.
Old Jan 26, 2014 | 12:49 PM
olfordsnstone's Avatar
olfordsnstone
Make sure to alternate torquing the T-housing bolts, (one then the other then back to the first etc.) evenly so to not crack the housing.
Old Jan 26, 2014 | 01:02 PM
Subzero68's Avatar
Subzero68
Great, I won't need a shop then. Whats the torque on the bolts and where is all this located? I just had my coolant flushed last month so could I re-use the coolant if I keep it clean as possible?
Old Jan 26, 2014 | 01:44 PM
olfordsnstone
I think the torque is around 17 pounds. Maybe one of the techs will correct me. I'd re-use the coolant, especially if it was just flushed a month ago.
Old Jan 26, 2014 | 02:11 PM
jswartz84's Avatar
jswartz84
17 ft lbs is correct
Old Jan 26, 2014 | 05:39 PM
CPB1's Avatar
CPB1
Old Jan 26, 2014 | 05:46 PM
69cj's Avatar
69cj
Originally Posted by CPB1
Some have two bolts and some such as my 05 have studs which means two sets of nuts to remove.
Old Jan 26, 2014 | 05:49 PM
78fordman's Avatar
78fordman
Taking out the air filter will be the biggest pain. I absolutely hate pulling the air filter, just a terrible design. From there everything gets better.
Old Jan 26, 2014 | 06:02 PM
69cj's Avatar
69cj
About 5 minutes once you have it down.
Old Jan 26, 2014 | 06:08 PM
05F250DSL's Avatar
05F250DSL
I just did this last night on my 05' I had bolts. Absolutely no need to pull the air filter or housing or cac pipe. Yes it makes for a little easier access but it took longer to drain the coolant than I did to loosen the two bolts and swap the thermostat. I also left the hose on to make it easier to pull it out. 17 ftlbs is what I found in All data as well. A rag stuffed In the opening and a piece is scotch Brite to clean the sealing surface mine wasn't to bad but I like mating surfaces clean.
Old Jan 26, 2014 | 06:29 PM
1345's Avatar
1345
What do you think about an aftermarket intake for the air filter?
Old Jan 26, 2014 | 06:36 PM
69cj's Avatar
69cj
I don't. Unless you have some extreme build up of the engine you'll gain nothing with an am filter except emptying you wallet.
Old Jan 26, 2014 | 06:44 PM
9228.bobcat's Avatar
9228.bobcat
Oem is the best you can get unless your producing big hp. Air filter is easy to get out. Take off your return coolant line. Take off your boot that runs to your turbo right before the ccv. Pull up from the back and it all comes out in one piece. Oh unhook your two sensors before you pull up.
