77 F100
Old Jun 28, 2003 | 01:10 AM
msgjvh's Avatar
msgjvh
77 F100
A friend of mine has a 77 F100 that has some typical rust but not alot. They want $800 for it but of course there are a few problems. The tranny shifts irracially almost as if downshifting to pass. The dash lights don't work and the turn signal cam is not working at all. Most of these are small fixes that a trip to a junkyard will correct. Only one I am really concerned with is the tranny. I think either the downshift rod is incorrectly connected or there is a vacuum problem somewhere. The VIN number is:
F10SRZ23053 I believe it has a 351w with a C6 but I can't find a vin decoder. Any ideas?
Old Jun 28, 2003 | 01:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
77 F100
Try this one:
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Old Jun 28, 2003 | 01:58 AM
overtork's Avatar
overtork
77 F100
what's up?ther is a vac line from the back of the intake manifold to the trany,ther might be two.one goes to the modulator.they go bad.{modulator}they are also cheap.better to spend,and loose 10 bucks then to spend 800,then another300 on a trany.you can disconnect the kick down linkage to see if it's adjusted improperly.with it disconnected the truck should shift up and down normaly,it just won't downshift when you hammer it.
Old Jun 28, 2003 | 11:38 AM
Mil1ion's Avatar
Mil1ion
77 F100
F10SRZ23053
77, F-100, 400 cu in,San Jose Truck number 23053
kmeifert
1997 - 2003 F150
76
Dec 16, 2023 09:37 PM
pintojoe
Mar 24, 2015 12:10 PM
77beater150
Oct 17, 2014 10:57 AM
74F100LGM
Oct 14, 2014 08:58 AM
Gsmitty53
May 10, 2014 02:38 PM
