Replace the ignition cylinder or not?
Old Jun 4, 2002 | 12:42 PM
adbradley's Avatar
adbradley
I have an 89 F-150 (6 cyl, 5 spd) and now I have no keys. It seems that my wife was driving it and lost the only set we had (my other set is at the bottom of a lake). I called the local locksmith and he wants $89 per key to make new ones. I can get a new cylinder and 2 new locks for $20 at the local parts store. Since I can't turn the cylinder to the On position to get to the pin, does that mean I will have to remove the steering wheel to get it out? Or am I stuck with getting one made by the locksmith? If I can get to it by removing the wheel, is there anything else I need to look out for, like maybe a security plate or any theft-deterrent devices? Thanks for your help...
Old Jun 4, 2002 | 12:53 PM
mantta's Avatar
mantta
I have the instructions for doing this (in a Chiltons manual). The procedure is different if you have a tilt steering wheel than a regular wheel. I will gladly e-mail s digital photo of the instructions if you give me an address and what type steering wheel you have.
Old Jun 4, 2002 | 01:02 PM
adbradley's Avatar
adbradley
I have a tilt wheel. The address is adbradley(No Email Addresses In Posts!). Thanks alot!!
Old Jun 4, 2002 | 02:36 PM
winfordr's Avatar
winfordr
[updated:LAST EDITED ON 04-Jun-02 AT 03:38 PM (EST)]Is your door key the same as the ignition key?
On my 92 F150 they were the same, so I bought a matched set of locks for the doors and ignition from Ford.
On my 88, the door key is cut backward from the ignition.
If your keys are the same, you could take the lock from your door and take it to the locksmith. He may reduce the cost if he doesn't have to make a house call.
Winford
Old Jun 4, 2002 | 07:13 PM
Pensive's Avatar
Pensive
FoxFord33
1978 - 1996 Big Bronco
May 8, 2014 05:05 PM
Spotty
1997 - 2003 F150
Mar 22, 2014 07:34 AM
John & Old Ford
Jul 30, 2012 04:15 PM
uncle.stosh
13
Feb 20, 2008 06:31 PM
borland
Apr 12, 2004 07:33 PM
