Gentlemen, steering question
Old Jan 25, 2014 | 07:59 AM
User 71024's Avatar
User 71024
It's been a while since I've been around, life has been trying my patience.
But I have a minor issue I was hoping some-one could help me with before I go searching junkyards.
I have a 79 F-150 2wd 8 ft bed, 460 auto with manual steering.
I built a bracket for a pump I have and bought a reman PS gear.
The only info I can not find, is if there is a difference between a power and manual pitman arm,(2wd), and if there is, is it just a length difference where I can use the wrong one but it may change the amount of travel?
anyone run across this yet?
Old Jan 25, 2014 | 07:56 PM
VocaTexas's Avatar
VocaTexas
I'll take a stab at this since nobody else has answered yet. I think if you have the recirculating ball type steering box, which looks very much like the Ford power steering box, it will use the same pitman arm. If you have the worm and sector type, which looks like a little square steering box, it will definitely use a different arm.
If I were you, I'd go to my local NAPA and have them look it up to be sure.
Old Jan 26, 2014 | 04:15 AM
User 71024's Avatar
User 71024
I couldn't find anyone that listed it, it doesn't have a ball, just the 2 machined ends, so they don't wear out, and because of that nobody makes it anymore.
I was just hoping for a hint from here, I have to bring it in my shop this week anyway, I'll scope it out then.
Old Jan 26, 2014 | 04:55 AM
User 71024's Avatar
User 71024
Originally Posted by 67Camarodude
I belong to a lot of other forums and I see your type all the time, we call you a "carpet bomber", your sole goal is to build up post count. You post a ton of replies, but very few of them are meaningful, most are just filler, or completely ridiculous altogether. I've watched this forum long enough to see most people just ignore you, you'd be better served if you just posted the good stuff and left the crap at home.
Who are you replying too? and why are you replying to every thread?
Old Jan 26, 2014 | 05:54 AM
gatorfor88's Avatar
gatorfor88
camarodude almost has to be some kind of bot.
Old Jan 26, 2014 | 06:43 AM
User 71024's Avatar
User 71024
LOL, I responded to that before my first cup of coffee this morning, figured it out a few seconds later.
Old Jan 26, 2014 | 06:54 AM
gatorfor88's Avatar
gatorfor88
I can relate. I cant even pee when I get up without havin a cup first.
Old Jan 26, 2014 | 09:10 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I think he was on a bender last night and had an issue with me and my posts, he posted that same reply to every thread I replied to.
Sorry folks.....
Old Jan 26, 2014 | 09:23 AM
lasthighboy's Avatar
lasthighboy
as long as the splined end of the arm is the same, it should mount up. 2wd and 4wd swap as well, along with some chevy and dodge applications. (70's and 80's 4wd chevy and ford highboy are different design) the length and drop could be different, as well as the size (and direction) of the tapered hole for the drag link. im not sure on 2wd, but I would think manual and power steering arms would be the same.
that being said, 2wd power gearboxes are very common. shouldn't be hard to find the correct arm.
Old Jan 26, 2014 | 10:41 AM
jason77F250's Avatar
jason77F250
Sorry folks.....
90% of his posts are the canned "carpet bomb" response. Dude is a wack job.
Old Jan 26, 2014 | 10:47 AM
fmc400's Avatar
fmc400
MSEE
This new guy is probably a fellow we know and love from Montana, back trolling after having been banned. Just a guess. I can't think of why anyone else would go through the trouble of doing this. The timeline would make sense, and it would explain why he's bashing 77&79F250 so much.
Old Jan 26, 2014 | 10:25 PM
77&79F250's Avatar
77&79F250
Looks like he was wiped off the forums all together, and for the record MontanaHB and I got along just fine.
Old Jan 26, 2014 | 11:11 PM
iggybob44's Avatar
iggybob44
Just for laughs i looked up a couple GM enthusiasts sites.......since his name Mentioned Camaros and he made a remark to me how i woulda been better had i purchased a 67-72 Chev/GMC pickup.....looked at members on a camaro site, and a GM truck site, not one guy with the name he used here.....
Old Jan 27, 2014 | 07:49 AM
fmc400's Avatar
fmc400
MSEE
Looks like he was wiped of the forums all together, and for the record MontanaHB and I got along just fine.
Gotcha. For some reason I thought I remembered him randomly attacking you on the forums for no reason, but then again he did that to a lot of folks (including me). Until all that happened, he was a pretty good person to have around; it's unfortunate. Oh well.
Old Jan 28, 2014 | 09:40 AM
77&79F250's Avatar
77&79F250
Yes he was the #3 guy to locate parts with skills like ND and mikeo0o0o0, to bad he is cruising some where else.
As far as the "camerodude"....good by chebby guy, lol.
Lug Nut
21
Jan 6, 2020 03:33 PM
cliff tate
Ford Truck Parts for Sale
Dec 18, 2016 06:54 PM
67camaro
Oct 13, 2015 12:09 AM
FordPickup460
Offroad & 4x4
Apr 29, 2006 12:34 AM
crjackson
Jan 27, 2006 12:25 AM
