6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
New Camshaft
Old Feb 5, 2014 | 02:25 PM
RM2738's Avatar
RM2738
Originally Posted by UGA33
My calculations were correct. At 96k, it had to be torn into. Here is the report. Shows work done by a dealer all the to 340k miles. <TABLE id=claim-grid class=grid><TBODY><TR><TD></TD><TD>287790</TD><TD>2</TD><TD>0</TD><TD>2.8</TD><TD>COURTESY FORD, INC.</TD><TD>1230</TD><TD>10-DEC-07</TD><TD>8C3Z</TD><TD>4200</TD><TD>FB</TD><TD>13723901</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>DIAGNOSE STEERING / SUSPENSION CONCERN. C/S LOUD NOISE IN THE REAR END. N51</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>TEST DROVE VEHICLE FOUND REAR AXLE NOISEY REMOVE CARRIER ASSEMBLY FOUND CAP BOLT BROKEN BOLT DAMAGED CARRIER NEEDS COMPLETE ASSEMBLY R/R CARRIER UNIT TEST DROVE VEHICLE FOUND NO PROBLEM AT THIS TIME</TD></TR><TR><TD></TD><TD>739228</TD><TD>E72</TD><TD>5</TD><TD>2.4</TD><TD>COVINGTON FORD, INC.</TD><TD>36572</TD><TD>14-APR-08</TD><TD>8C3Z</TD><TD>8501</TD><TD>B</TD><TD>02181301</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CUST STATES VEHICLE IS LEAKING COOLANT</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>REPLACE WATER PUMP,CUST HAS LEAK FROM RADIATOR,WILL BRING BACK TOMARROW FOR REPAIR,NEEDS TO TAKE VEHICLE</TD></TR><TR><TD></TD><TD>1797467</TD><TD>S07</TD><TD>11</TD><TD>2</TD><TD>LOGANVILLE FORD</TD><TD>88982</TD><TD>13-OCT-08</TD><TD>8C3Z</TD><TD>9J460</TD><TD>A</TD><TD>049215B</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CUST STATES AT 65MPH LOSSING POWER</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>LOSS OF POWER EP SENSOR EGR VT SENSOR R AND R EP SENSOR AND EGR VT SENSOR</TD></TR><TR><TD></TD><TD>1797468</TD><TD>E72</TD><TD>11</TD><TD>5.1</TD><TD>LOGANVILLE FORD</TD><TD>88982</TD><TD>13-OCT-08</TD><TD>8C3Z</TD><TD>6F073</TD><TD>A</TD><TD>049215A</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CUST STATES HOSE TO TURBO KEEPS COMMING OFF</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>TURBO HOSE COMING OFF TURBO HOSE AND OIL R AN R FRONT CRANK SEAL AND COOLER HOSE</TD></TR><TR><TD></TD><TD>1921137</TD><TD>08B06</TD><TD>11</TD><TD>.3</TD><TD>LOGANVILLE FORD</TD><TD>90602</TD><TD>23-OCT-08</TD><TD>*</TD><TD>*</TD><TD>*</TD><TD>049564C</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>RECALL 08B06 VENTURI T</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>INSTALL TEE PER RECALL</TD></TR><TR><TD></TD><TD>1921135</TD><TD>E72</TD><TD>11</TD><TD>1</TD><TD>LOGANVILLE FORD</TD><TD>90602</TD><TD>23-OCT-08</TD><TD>8C3Z</TD><TD>12B591</TD><TD>B</TD><TD>049564A</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CUST STATE HAS NO POWER</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>NO POWER EGR SENSOR R AND R SENSOR</TD></TR><TR><TD></TD><TD>1921136</TD><TD>08B07</TD><TD>11</TD><TD>.5</TD><TD>LOGANVILLE FORD</TD><TD>90602</TD><TD>23-OCT-08</TD><TD>*</TD><TD>*</TD><TD>*</TD><TD>049564B</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>RECALL 08B07 PCM REPROGRAM</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>REPROGRAM PCM PER RECALL</TD></TR><TR><TD></TD><TD>2469225</TD><TD>08B06</TD><TD>12</TD><TD>42.5</TD><TD>COURTESY FORD, INC.</TD><TD>96206</TD><TD>12-NOV-08</TD><TD>*</TD><TD>*</TD><TD>*</TD><TD>15484701</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>DIAGNOSE DIESEL DRIVEABILITY CONCERN CK ENGINE LIGHT ON</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>D DIAG STEPS 1 16 FAILED RELITIVE COMP ON 1 2 8 R AND R VALVE COVER FOUND ROCKERS WORN BUT NO VISABLE DAMAGE CALLED HOTLINE SAID TO FIND CAUSE FOR RUNNING HOT FIRST FOUND RAD LEAKING AND EGR COOLER LEAKINGCOMP TEST 1 2 8 AT 20 0 PSI 7 AT 250 REST AT 390 CONTACT HOTLINE TOLD TO R R OIL PAN TO INSPECT BENT ROD R R CAB R R AFTER MARKET WRECKER CONTRAOLS AND PTO R R HEADS #1 PISTON MELTED 2 7 8 STA</TD></TR><TR><TD></TD><TD>2190651</TD><TD>E72</TD><TD>12</TD><TD>1</TD><TD>COURTESY FORD, INC.</TD><TD>96206</TD><TD>12-NOV-08</TD><TD>8C3Z</TD><TD>12B591</TD><TD>D</TD><TD>15484702</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>DIAGNOSE DIESEL DRIVEABILITY CONCERN CK ENGINE LIGHT ON D50</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>PERFORM DIAG CODES P2033 PERFORM PINPOINT TEST FOUND SENSER OPEN ON RESISTANCE OUT OF SPEC REPLACE EGT SENSER TEST DRIVE WENT INTO REGEN AFTER REGEN SET CODE FOR 2 EGT SENSER PERFORM PINPOINT TEST FOR SENSER ALSO OUT OF SPEC RANGE OPEN REPLACE SENSER AND TEST DRIVE AGAIN ALL PASS</TD></TR><TR><TD></TD><TD>4021052</TD><TD>SSP</TD><TD>20</TD><TD>6</TD><TD>COURTESY FORD, INC.</TD><TD>148140</TD><TD>14-JUL-09</TD><TD>*</TD><TD>6007</TD><TD>*</TD><TD>16775001</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>DIAGNOSE DIESEL DRIVEABILITY CONCERN C/S VEH. IS LEAKING COOLANT. L87</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>PERFORMED COOLING SYSTEM PRESSURE TESTS, DIAGNOSED A PIN HOLE IN THE FRONT ENGINE COVER, CONTACTED HOTLINE AND WAS INSTRUCTED TO INSTALLED NEW FRONT COVER,WATER PUMP,AND THERMOSTATS. INSTALLED NEW FRONT COVER GASKET AND FRONT COVER ASSEMBLY,NEW WATER PUMP,AND NEW THERMOSTATS. REASSEMBLED ENGINE,REFILLED WITH COOLANT,CHANGED OIL AND FILTER,ROADTESTED,RETESTED,OK.</TD></TR><TR><TD></TD><TD>4308008</TD><TD>SSP</TD><TD>21</TD><TD>14.8</TD><TD>MIKE FITZPATRICK FORD, INC.</TD><TD>159179</TD><TD>20-AUG-09</TD><TD>*</TD><TD>6007</TD><TD>*</TD><TD>03653501</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CUST STATES VEH IS OVERHEATING AND HAVING TO ADD COOLANT. ALSO OIL IN COOLANT AND WAS TOLD POSSIBLE BLOWN HEAD GASKETS</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>VERIFY CONC,COOLANT IN OIL,DRAIN OIL,PRESS TEST COOLING SYS,COOLANT LEAKING FROM OIL DRAIN PLUG,R I OIL PAN TO DETERMINE SOURCE OF COOLANT LEAK,LEAKING FROM FT OF ENGINE,R I WATER PUMP AND FOUND FT COVER CAVITATED. REPL FT COVER,WATER PUMP,BOTH THERMOSTATS,UPPER AND LOWER OIL PAN GASKETS,CHANGE OIL AND FILTER AND RD TEST AFTER REPAIRS.</TD></TR><TR><TD></TD><TD>4325136</TD><TD>SSP</TD><TD>21</TD><TD>14.8</TD><TD>MIKE FITZPATRICK FORD, INC.</TD><TD>159179</TD><TD>20-AUG-09</TD><TD>*</TD><TD>6007</TD><TD>*</TD><TD>03653503</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CUST STATES VEH IS OVERHEATING AND HAVING TO ADD COOLANT</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>VERIFY CONC,DRAIN OIL,PRESS TEST COOLING SYS,COOLANT LEAKING FROM OIL DRAIN PLUG,REMOVE OIL PAN TO DETERMINE SOURCE OF COOLANT LEAK. LEAKING FROM FT OF ENGINE. R I WATER PUMP AND FOUND FT COVER CAVITATED. REPLACED FT COVER,WATER PUMP AND BOTH THERMOSTATS,UPPER AND LOWER OIL PAN GASKETS,CHANGE OIL AND FILTER AND RD TEST AFTER REPAIRS.</TD></TR><TR><TD></TD><TD>4881663</TD><TD>SPW</TD><TD>25</TD><TD>0</TD><TD>MIKE FITZPATRICK FORD, INC.</TD><TD>198005</TD><TD>02-DEC-09</TD><TD>8C3Z</TD><TD>8009</TD><TD>B</TD><TD>03975902</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>COOLANT LEAKING FROM RADIATOR SPW</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>REPLACED RADIATOR</TD></TR><TR><TD></TD><TD>4881664</TD><TD>SSP</TD><TD>25</TD><TD>2.4</TD><TD>MIKE FITZPATRICK FORD, INC.</TD><TD>198005</TD><TD>02-DEC-09</TD><TD>*</TD><TD>6007</TD><TD>*</TD><TD>03975901</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CUST STATES COOLANT LEAKING CK AND ADV SEE HIST</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>PRESSURE TEST COOLING SYSTEM REPLACED WATER PUMP</TD></TR><TR><TD></TD><TD>7269396</TD><TD>SSP</TD><TD>40</TD><TD>9.4</TD><TD>MIKE FITZPATRICK FORD, INC.</TD><TD>340442</TD><TD>03-MAR-11</TD><TD>*</TD><TD>6007</TD><TD>*</TD><TD>05410501</TD></TR><TR class=details><TD><TD class="edge boldlabel" colSpan=2>Customer Comments</TD><TD class=comments colSpan=9>CK ENGINE LIGHT STAYS ON CK AND ADV HAS ENG WARR</TD></TR><TR class=bottom><TD><TD class="edge boldlabel" colSpan=2>Tech Comments</TD><TD class=comments colSpan=9>PERFORMED DIESE DIAG STEPS 1 5.CONFIRM DTC P0088.PP TEST,R I CAB TO REPLACE HIGH PRESS FUEL PUMP,REINSTALL CAB,REFILL NEC FLUIDS AND RD TEST,OK AT THIS TIME</TD></TR></TBODY></TABLE>
Here's the report.
Old Feb 5, 2014 | 04:16 PM
UGA33's Avatar
UGA33
I looked all over for that thing. Under the customer comments on that last entry past 300k, it states HAS ENG WARR. Does that mean a Ford covered warranty or an aftermarket warranty coverage plan?
Old Feb 5, 2014 | 05:03 PM
RM2738's Avatar
RM2738
I'm using a mobile app so I can't read it, but if I recall correctly, didn't they replace the engine at one point? Two HPFP? Maybe workmanship warranty?
finneys98xj
Jan 7, 2012 02:35 PM
packrat56
Jun 12, 2004 08:49 PM
jeffbran
Apr 28, 2004 09:23 PM
jeffbran
16
Apr 23, 2004 01:07 PM
Berlinetta00
Jun 6, 2003 05:45 PM
