Overhead console upgrade for XLT?
Old Jan 23, 2014 | 10:24 PM
TheCurtster's Avatar
TheCurtster
My Ex is an XLT model, as I'm really not fond of leather, but one thing I do like on the limited models is the trip computer/OAT digital indicator on the overhead console. I pulled mine off this morning and there's an unused connector sitting right there where it oughtta be for the display.
Does anyone know if I buy a display unit from a Limited will it work from that plug? I believe that lots of autos use the same wiring harness from base to Gucci models, and it's just matter of what's ultimately installed. Thoughts?
Curt
Old Jan 23, 2014 | 11:02 PM
Apocalypse's Avatar
Apocalypse
I would think so yes, but I would wait for someone that is a little more knowledgeable than me to chime in.
Old Jan 24, 2014 | 07:09 AM
TNScrambler's Avatar
TNScrambler
I've been told that most XLTs are pre-wired for it, but I don't know that for a fact....Even if its not prewired it can be done. We just put on in my cousin's XL early '99 F250SD 7.3. Of course we had to run wire up to the temp sensor, and then tap into the harness to get all the correct feeds to get the OHC the correct info for all the MPG stuff. But, I've been told that alot of the XLTs were prewired. Check the connector up there and see where it does, it should run over to and down the passenger side a-pillar and down to another connector in the passenger side kick-panel. My cousin's xl truck had the connector in the kick panel, but only had 2 wires running into it.
If you do some google searching you can find the pinnout diagram for the harness and you can check to make sure all the correct color wires are up there, if so, you'll just have to get a OHC, install it, and plug it in. If not you can run the wires like we did for my cousins truck. Either way it is doable.
Justin
Old Jan 24, 2014 | 08:45 AM
fastang50's Avatar
fastang50
My XLT has the display up there. It's an 05, also has leather so maybe it's related?
Old Jan 24, 2014 | 09:03 AM
ExxWhy's Avatar
ExxWhy
Wondering what you have up there now. My XLT also has the lie-o-meter, DTE, and temp display. 2000 with cloth seats.
Old Jan 24, 2014 | 09:11 AM
Archion's Avatar
Archion
Veteran: Marine Corps
My XLT is a cloth model. Has the trip computer, so it can be done.
Old Jan 24, 2014 | 09:54 AM
TheCurtster
Originally Posted by ExxWhy
Wondering what you have up there now?
I have a big black plug that says Excursion, so in case I forget what I'm driving I can just look up there, and whaddayaknow, I'm driving an Excursion!
I think I'm going to watch for one and see what happens.
Curt
Old Jan 24, 2014 | 12:25 PM
PoPs 03DEX's Avatar
PoPs 03DEX
Yes it should work.
Son in-law has same yr XLT with display should be plug & play.
Old Jan 24, 2014 | 01:43 PM
Mr. Crab's Avatar
Mr. Crab
Gotta admit; I LOL'd!
Old Jan 24, 2014 | 02:53 PM
icentropy's Avatar
icentropy
Curt
Not too easy to find one. I haven't seen any for sale individually. Normally have to buy the whole overhead console, and even then most don't include the display. Here's a pretty reasonably priced one.
Overhead Console Digital Display
Old Jan 24, 2014 | 06:50 PM
WE3ZS's Avatar
WE3ZS
My '05 cloth XLT just has the grey plug in place of the lie-o-meter too. Was originally part of Uncle Sam's fleet, at least I have carpets and a third row.
Old Aug 15, 2019 | 09:35 PM
panstep's Avatar
panstep
HI Curt- Saw Overhead console upgrade for XLT you started a few years back and wondering if any success? My 2004 Ex is also an XLT and would like to perform the same upgrade. Thank you very much in advance! Step.
Old Aug 15, 2019 | 09:57 PM
panstep's Avatar
panstep
Hello Curt- HI again. More specifically, mine has a grey male connector anchored in the headliner that is not in use and I would like to know if this is the same "unused" connector you were referring in your initial thread? Are you able to confirm if this grey connector is indeed for trip computer? What I am also bewildered is that I believe the connector that comes out of the trip computer is in the same male gender? Thanks again!
Old Aug 16, 2019 | 05:48 AM
WE3ZS's Avatar
WE3ZS
Hey Pan, Welcome to the Ex forum!
It looks like Curt's last visit here was back in Nov '17, so I'm not sure if he will respond. But yes, that grey connector should be the one for the lie-O-meter in the overhead, it seems that harness is shared by all trim levels and options, you will need to also add the temp sensor that mounts to the header panel/radiator support under the hood.
Also consider starting a new thread to introduce yourself and show off your EX.
Old Aug 16, 2019 | 01:51 PM
panstep's Avatar
panstep
Hi Tom, thank you for the greetings and very nice to meet you virtually. Presumably the grey connector is there intended for trip computer add-on, do you know how the actual connection would work? From my research, the connector that comes out of the trip computer is in the same gender as my unused grey connector...
Thanks again,
