Help Battery draining overnight
Old Jan 22, 2014 | 06:44 PM
elvaktran's Avatar
elvaktran
Hi, I have an 1998 expedition EB. a week ago I started having a problem that overnight it drains the battery. I found what it is but know I have a doubt. apparently the alternator is draining the battery. with the amp meter i did have a 4.33 amp draw, and after searching around I found that when disconnecting the alternator inline mini fuse (20 Amp) it dropped to 0.2 Amps. Now here is my question. Do I have to replace the alternator or the voltage regulator? or it can be something else? Thanks in advance for your help. will
Old Jan 22, 2014 | 07:00 PM
JWC 3's Avatar
JWC 3
Unhook the alternator itself . The battery wire and the regulator plug . Leave the fuse in . Then see if you have a draw . If you do, replace the alternator or have it rebuilt .
Old Jan 22, 2014 | 07:08 PM
elvaktran's Avatar
elvaktran
thank you JCW_3 I will try it now if not tomorrow cause its getting cold here!
Old Jan 22, 2014 | 07:16 PM
JWC 3's Avatar
JWC 3
Good Luck ! One more thing , be sure you insulate the main battery wire so it does not short out .
Old Jan 25, 2014 | 12:41 PM
elvaktran's Avatar
elvaktran
here it is. After TS the charging system found that the alternator was fried. it has a 4.27 Amp draw with everything off. The alternator was so shot that it was drawing AMp as a motor. Removed Alternator and did further testing in Autozone and failed everything. Replaced alternator IAW specs. Now its working good with 0.02 Amp draw that its within manufacturers specs. The rare thing here was that the alternator was still charging at 14 volts. I still can't figure that one out. Thanks JWC_3 for all your help.
Old Jan 25, 2014 | 02:02 PM
JWC 3's Avatar
JWC 3
Glad you got it fixed ! Thanks for posting your fix . It is not as rare as you think , I see it a couple of times each year .
Old Jan 25, 2014 | 02:20 PM
SilverSS's Avatar
SilverSS
Glad you figured it out. Alternator probably had a bad diode. I've got a battery drain on my Dodge right now I'm still trying to find. Going to rip out the carpet tomorrow and start tracing wires. Yay.
WMNY
Dec 5, 2010 08:59 AM
storm96
Electrical Systems/Wiring
Nov 13, 2008 10:27 PM
mandrielle
Sep 3, 2007 04:14 PM
justine's77ford
Jan 9, 2007 03:22 PM
Rupenthal94F150
Dec 17, 2005 05:17 PM
