Emergency Brake stopped working
Old Jan 22, 2014 | 05:47 PM
Merlin Miller's Avatar
Merlin Miller
Thumbs down Emergency Brake stopped working
my emergency brake popped when i pushed down on it and now it doesn't work. Is this common?
Old Jan 22, 2014 | 06:24 PM
Diesel_Brad's Avatar
Diesel_Brad
Welcome to the forum.
I suggest returning your for back to normal
As for your e-brake, yes it is semi common. It sounds like you broke a cable
Old Jan 22, 2014 | 09:20 PM
Mike1's Avatar
Mike1
I had the same thing happen back in the fall, went to set the brake and snapped the cable. Still haven't fixed it, Just can't leave it in neutral...LOL
Old Jan 22, 2014 | 10:22 PM
Puddy's Avatar
Puddy
Look for broken cables along your drivers side frame.
Also are you dragging your rear brakes?
Old Jan 23, 2014 | 11:43 AM
Merlin Miller
Not sure what you mean by dragging my brakes.
Old Jan 23, 2014 | 11:49 AM
Mike1's Avatar
Mike1
I believe he means when you pushed on the Ebrake did the brakes start to set then the cable broke? If it did then your parking brakes are partially applied and they could cause overheating, pad ware and bad gas mileage.
Old Jan 23, 2014 | 01:20 PM
88n94's Avatar
88n94
Well, if the cable broke the brakes would release and not be holding. Or am I missing something here?
Old Jan 23, 2014 | 01:24 PM
mrrish79's Avatar
mrrish79
Sometimes the cable slips from its place along the drivers frame, midway down the frame. I had it slip out of the bracket. That's the best way I can explain it without a picture.
Old Jan 23, 2014 | 01:28 PM
dixie460's Avatar
dixie460
No you're right, if the cable broke then the brakes would release.
Old Jan 23, 2014 | 03:52 PM
Merlin Miller
I am getting horrible gas mileage. Could that really be the reason?
Old Jan 23, 2014 | 04:47 PM
Puddy's Avatar
Puddy
In the rust belt, I've had my cables snap and seize in the protective sleeve.
Have you inspected anything?
Old Jan 23, 2014 | 04:56 PM
88n94's Avatar
88n94
You wouldn't have to drive very far before one or both the rear drum(s) got HOT. Had you been using your parking brake regularly?
Old Jan 23, 2014 | 07:01 PM
Merlin Miller
It broke a long time ago. I've probably only driven about six months worth since but my gas mileage is ridiculous. After reading this thread it did feel like the brakes were dragging. I haven't inspected anything yet. i just thought i broke something and didn't ever feel like fixing it but my truck rolled back down a gradual grade the other day parked in gear. So i posted this ad. Getting better gas mileage would be greatly appreciated. If i find the cable has worked itself loose of the guide or snapped what all is involved in replacing or fixing it. What kind of expenses might i incur? Any and all feedback is greatly appreciated. Thanks everyone.
Old Jan 23, 2014 | 07:03 PM
Merlin Miller
And yes I was applying the e brake when pedal just popped and dropped to the floor.
Old Jan 23, 2014 | 07:42 PM
scorekeeper58's Avatar
scorekeeper58
It sounds exactly like a broken cable. This link will show you a drawing of the parking brake cable system:
Truck Parts and Truck Accessories
The cable from the pedal runs under the left (driver's) side of the cab. About the back of the cab, the equalizer (part # 11) splits to two cables, one to each rear wheel. Either one of the cables broke or pulled through the equalizer.
