Bronco II Ford Bronco II
no spark
Old Jan 21, 2014 | 04:51 PM
beckman's Avatar
beckman
no spark
Hi everybody still working on my bronco 2 1990 2.9
changed the TFI module and ignition coil and still no spark
there is a fuse that was blown it was the engine com LP fuse it said
when i put a new 15 amp fuse in it it blows right away not sure if that has anything to do with my no spark issue i could sure use some help on this issue thanks everybody
Old Feb 11, 2014 | 06:53 PM
Bills86e's Avatar
Bills86e
Does the starter crank over the engine? Start with the Basics. Could be
in a harness.
Old Mar 11, 2014 | 09:02 PM
tchile's Avatar
tchile
I usually solve my spark problems with the info in the tech guide. Wiggle the wire going into the coil on the left side of coil. Make sure fuel pump is powering up in the first key position where inst. lights come on. It is a distinct sound for about 2 seconds. If no sound check fuel tank elect connector on top of tank.
Revmitchell
Oct 11, 2014 12:01 PM
copuntryboy
1997 - 2003 F150
Apr 20, 2012 10:32 PM
cbass139
18
Sep 11, 2009 02:55 PM
ord problem
1997 - 2003 F150
Jul 6, 2005 09:06 PM
vj_M
Bronco II
May 8, 2004 03:44 PM
